Co2 Cooling System *NEW IDEA*
Old Mar 31, 2002
NukeSilo's Avatar
NukeSilo is an unknown quantity at this point
hmmmm well i was sitting here in my room pondering about a new idea. What i was thinking was having a Tank in my trunk bout the same size as a N2O tank, have a line run it to my engine bay going to some brand gas Solenoid. the output would then go to a copper coil which would be wrapped around my CAI and then the output of that to my Z3 slits. When im running my N2O i could turn the Co2 on and it would cool down the intake air and also giva a way cool effect. It wouldnt be that much $ to set up cause i would just need to purchase a gas Solenoid and lines plus Co2 can be filled alot of places and cheap. by the way what are the name of those lines, you know the metal ones you run N2O on. well whatcha guys think, good idea or what info if it would work would be appreciated thanks [IMG]i/expressions/beer_yum.gif[/IMG]
Old Mar 31, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Well you could use compressed air too I would think since compressed air is cold. And you could have the compressed air inject right into the air steam but I doubt anything liek that would be very noticible and not worth your time to even try and do. But if you do then good luck!
Old Mar 31, 2002
NukeSilo's Avatar
co 2 runs alot colder then compressed air plus it wouldnt cost that much $ so i thinkim gona do it
Old Mar 31, 2002
black's Avatar
black is an unknown quantity at this point
Hmm... [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Isnt that bad for the engine though, since it has NO oxygen? Im not a rocket scientist, plus I hate chemistry but.. I duno, just thinking logically. Hella great concept though.
-=- peAce -=-
Old Mar 31, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
No, that is not going to yield any HP gains. NA really doesn't make much use of this technique, maybe only .5 HP if that. FI on the other hand, this kind of thing would work great.
Old Mar 31, 2002
streetfxracer's Avatar
streetfxracer is an unknown quantity at this point
hey guys hate to inform you but its been done the co2 runs though a intercool type object and and cools the air its for cars that can't run nitous or turbos i think nx makes it i saw it in a superstreet ad plus if you do a search someone asked about that earlier also
Old Mar 31, 2002
PerfectD3's Avatar
No sh*t it has been done Einstein, if you read my post a setup like this doesn't yield 100000000HP
Old Apr 1, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
just something to do, and another mod to list in your ride info
would still be a pretty interesting mod, especially if you did it in a way that the cooling coils looked tricked out, as to impress anyone checking out your engine bay.
Plus a blow off out the sides of your fenders.... would that be considered Uncle Ben's?
would still be cool though
Old Apr 1, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
i think "Every 40 degrees makes a difference of 6% HP".....so.....if you could CHILL the crap out of your CAI, then it would be a big
peace
Old Apr 1, 2002
NukeSilo's Avatar
cool coool, does any 1 have a link to that cooling thing from NX i cant find that product for some weird reason, i think im gona try my idea on the intake, whats there to waste.[IMG]i/expressions/beer_yum.gif[/IMG]
Old Apr 1, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
I was thinking of the same idea, but using it for NA cars not with N20. I figure that if you wrape the copper tubing around the whole lenght of the CAI, and hit the bottle, the tubbing with freeze and make the intake wicked cold. I remember when I used to play paintball that the barrell would become extremely cold, so why not use the same system on your intake? You wont get great HP gains, but if you are on the high way, and using it with conjunction with your CAI you will get a little extra boost.
Old Apr 1, 2002
avenger's Avatar
avenger is an unknown quantity at this point
think though, you are dealing with an aluminum intake tube about 5 inches away from a warm as hell engine. Its not like its going to freeze down to subzero and chill the air to give 20hp, you may see a gain of 2 hp IF THAT... its not worth the effort
Old Apr 1, 2002
bhaz413's Avatar
<< think though, you are dealing with an aluminum intake tube about 5 inches away from a warm as hell engine. Its not like its going to freeze down to subzero and chill the air to give 20hp, you may see a gain of 2 hp IF THAT... its not worth the effort >>
I agree with you. I dont think that there will be that much of a gain considering the engine would be blistering hot. But I think it would be a cool DIY for some extra HP. Shouldnt be less then 100 bucks to make.
Old Apr 1, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
I love how people throw around HP numbers like its a friggin lotto....
Old Apr 1, 2002
NukeSilo's Avatar
i was guessting between the 0 and 120 HP range............... give or take[IMG]i/expressions/beer_yum.gif[/IMG] ohhh fun project though
Old Apr 1, 2002
Travii's Avatar
Travii is an unknown quantity at this point
You could put it inside the intake and cool the air that way instead of the outside of the CAI and then cool the air. Would save a step and all you would have to do is cut two holes in the CAI for the CO2 lines to go in and out and seal them up real good. Might increse HP little bit more.
Old Apr 2, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
<< WhiteRiceBoi >>
HAHAHAHHAHAHA!!!!!!!!!!![IMG]i/expressions/laugh2.gif[/IMG]
Well said!! Hey, is it just me or have you been gone for a while? In any case, good to see you!
Old Apr 2, 2002
YEH FOO I BEEN OUT A LONG WHILE BEEN OUTTA THE MODDING THING CAUSE OF LACK OF MONEY..PLUS THE POSTS ALL GOT REDUDNDANT THERE WAS NOTHIGN NEW....
sorry about caps..too lazy to rewrtire..u inderstand
how u doin man? got sum new toyz"?
Old Apr 3, 2002
Oh boy...new toys huh?
I have A LOT of new toys
Old Apr 3, 2002
Grey's Avatar
DIY King
Travii is right. You'de have to cool the air inside the intake. If you cool the intake itself, then it doesn't have enough surface area to cool down the air inside the intake. Remember that air itself is a pretty good insulator. You would need an intercooler core for this to work. Hook all of the little tubes that run through the intercooler to the CO2 and let it pass through the intercooler and out into the air. Then encase the intercooler inside the intake. A regular CAI wouldn't be good for this. You'de need something like the stock airbox with more space for an intercooler. That's basically it. You'de get some good gains with FI (Forced Induction), but for a NA (Natually Aspirated) engine it wouldn't be as beneficial.
Old Apr 3, 2002
black's Avatar
Grey good job man!
JMO, but i think thats one of your best posts this year! lol [IMG]i/expressions/laugh2.gif[/IMG]
Old Apr 3, 2002
Grey's Avatar
DIY King
[IMG]i/expressions/laugh2.gif[/IMG] Will you quit it...
Old Apr 3, 2002
ph0ng's Avatar
Now we could take this one step farther...
Lets say we have the intercooler, but instead of just dumping a tank of CO2 to cool it down, why not use an already supplied coolent to do the job. Like making a by-pass on the Freon hoses and routing it thru the intercooler.
LOL
Just another pointless idea
Old Apr 3, 2002
Grey's Avatar
DIY King
Yeah, that would work. I posted that a long time ago. Have a compressor (just like an AC) to cool down the air and two intercoolers. It would work. Again, with FI you would see the gain, but with NA it's kinda pointless.
Old Apr 3, 2002
totally off subject but grey i thought that black was banned from the forum[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 4, 2002
Grey's Avatar
DIY King
Actually... He was. Then he apologized to Derek, so Derek un-banned him.
cukaracha
30
Jul 26, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
hayden55
Jul 8, 2015 11:38 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
ZILLA
Jul 5, 2015 05:24 PM
