Car won't idle!
Old Mar 25, 2002
pichon's Avatar
pichon is an unknown quantity at this point
Car won't idle!
Hey guys, maybe someone can give me a hand i am having trouble with my car's idle. it idles at about 600 rpm. i tried to raise the idle to about 1000 rpm by adjusting the tiny screw at the throttle body and it works, sort of,...but only when the car is warm. when its cold it goes up to about 1500 and its starting to **** me off!!! [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
not to mention it has a small miss-fire that i can't figure out. it only does it when its idleing, and when i accelerate it doesn't miss-fire, but the acceleration is rather sluggish. i think it might be the injectors or maybe the spark plugs...let me know any suggestions!
Old Mar 25, 2002
avenger's Avatar
avenger is an unknown quantity at this point
Doesnt the car adjust its idle when it's cold? I know theres no actual choke, but this is whats bumping the idle up.
My car never had a problem misfiring but it did have a problem where it would idle at 600, but then it would suddenly drop to about 250rpm and shudder, then recover.
Old Mar 25, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
the car is supposed to idle at 600 rpm when it's warm. it's also supposed to idle higher when it's cold, this is to warm the engine up faster.
Old Mar 25, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
"My car never had a problem misfiring but it did have a problem where it would idle at 600, but then it would suddenly drop to about 250rpm and shudder, then recover. "
me 2
the car idels higher when its cold to get the engine to operating temp faster.
thats normal
your car should not be backfiring! the one mod that can make your car back fire is an exhaust that doesn't provide any backpressure. what mods have you done?
Old Mar 25, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
You got it. There are basically 2 idles for the Civic, cold idle, usually around 1,200RPM and then there the idle when its warm which is usually around 600rpm. Don't go messing with screws that you think are idle adjustments. You probably adjusted a fuel/air mixture screw. If you didn't know that much about idle, I highly doubt that you know what you are doing when it comes to making tuning adjustments.
Old Mar 25, 2002
Mbow's Avatar
Yea, I wouldn't go playing with any screws. Just take it in to the dealer and have em fix it.
Old Mar 25, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
600 is the norm for when your engine is warm dood
Old Mar 26, 2002
Confinement's Avatar
Confinement is an unknown quantity at this point
the engine idle is supposed to be anywhere from 600-700 and usually a cold engine idles at about 1500 till it warms up then it goes down, if i was you i wouldnt mess with the idle speed screw, it just makes things more complicated, there really isnt any reason for you to be doing it, i found that out by experience, it doesnt do anything big for your speed but it does lower your gas mileage
Old Mar 27, 2002
greg2k1's Avatar
greg2k1 is an unknown quantity at this point
Idle Air Bypass Valve. Maybe faulty or depending on your kilometers it's all gunked up.
mikemc422
Aug 9, 2018 05:41 PM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
streetglower123
Apr 12, 2015 10:56 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
