please check my tire numbers fast !
Old Apr 5, 2002
Cypher's Avatar
Cypher is an unknown quantity at this point
ok i am setting up a deal for rims and tires.....the guy has 215/40/17 rim width fits but the guy says that the tire width woudnt and would rub on lowered civics....i have Neuspeed Sports which come out to around 2 inch drop....please confirm if the numbers WILL or WILL NOT fit.....please make sure your right because its a big deal going thanks for all your help
Old Apr 5, 2002
Spider883's Avatar
9K Redline Owns U
they should work without a problem
Old Apr 5, 2002
Cypher's Avatar
are you sure [IMG]i/expressions/face-icon-small-frown.gif[/IMG] i need a definite OK from maybe someone who already has them with a low drop. thanks though
Old Apr 5, 2002
Spider883's Avatar
9K Redline Owns U
ok sorry i couldnt help but in may i doing the same thing u are doing. good luck
Old Apr 5, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
YES they will fit.....215/45/17 will also fit and is closer to stock diameter
Old Apr 5, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
have that exact setup, doesn't ever rub. However, you need to make sure that the offset of the rims is either +40 or +42 or they may have a chance of rubbing...
Old Apr 6, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
<< have that exact setup, doesn't ever rub. However, you need to make sure that the offset of the rims is either +40 or +42 or they may have a chance of rubbing... >>
yups... basicly the offset will tell you will they rub or not... i've done months and months of researching for what size 18" wheels will fit best for our cars. The Honda Dealer has a 2002 civic on 18"x7.5" rims wrapped with 215/40/18 on +42MM offset. they said it doesnt rub at all! so for 17"s.... you cant go wrong with +42MM
bo_red
Apr 23, 2015 10:09 PM
technosilver
Nov 14, 2001 10:58 AM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
