body roll & strut bar?
Old Mar 31, 2002
jro's Avatar
jro
jro is an unknown quantity at this point
i am wanting to decrease the side to side body roll when going around corners. is an upper strut bar the answer to my problem? if not, then what? thanx!
- jro
Old Mar 31, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
upper strut bar, rear upper strut bar, and rear lower tie bar
Like NoBottleJustThrottle said, Sway Bar are the good way to go...but if u have an EX, u got factory sway bars already...but not as good as the aftermarket ones though
Old Mar 31, 2002
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
i would have said even more that strut bars...sway bars, a good set of sway bars will take out significant "sway" through your turns
Old Mar 31, 2002
2k1Miami's Avatar
2k1Miami is an unknown quantity at this point
Stiffer springs is a must, then sway bars
Old Mar 31, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
springs and struts
Old Mar 31, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Strut bars will help, but to really set it up right get springs, adjustable struts, and swaybars also. Someone installed the RSX rear sway bar which is 19mm vs. the EX's 12mm and said it made a big difference. It's seems like the 7th gens roll way too much in the rear! A perfect swap out and pretty cheap at around $77 for all the parts. Definitely one of my next mods.
Old Mar 31, 2002
jro's Avatar
jro
so the rsx sway bar will help? is it, for the most part, a bolt on type mod? also, i know that the rsx sway bar is stiffer, but is it stiff enough to cause hella oversteer in our cars? i'd like to get rid of body roll but i don't want to accidentally do a 360 when i try to avoid a deer or something.[IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 31, 2002
BAK's Avatar
BAK
Here's the thread with the info. It's a straight bolt on swap. Just need to replace the bushings and bushing mounts.
RSX rear sway bar
Also, here's the place to order them at.
Acuraautomotiveparts.net
Old Apr 1, 2002
jro's Avatar
jro
sweet thanx!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
honda.lioness
16
Feb 10, 2017 10:53 PM
Strycker
Aug 2, 2015 08:40 PM
mHo2
Jul 27, 2015 12:57 PM
fordover
Jul 11, 2015 09:10 PM
