HELP! i'm doing the front springs, and the tie rod
Old Mar 24, 2002
sorphin's Avatar
sorphin is an unknown quantity at this point
won't come off of the ... shock tower.. i tried using a tie rod seperator, but all that's succeeded in doing, is pushing.. grease out of the rubber thing between the tie rod and where it meets the tower... someone advise asap, what else i can do.. [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
thanks
-ds
Old Mar 24, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
put the fork in there and twist...if that dont work, bang it in with a hammer, those are tight suckers...oh ya, do this first so there isnt as much stress on it, it pops off much easier.
Old Mar 24, 2002
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Just take a hammer and hit it where i marked in the picture. Hit it hard. It will seperate. Just DO NOT try to hit the tie rod, you will screw it up.
Old Mar 24, 2002
2k1civicman's Avatar
2k1civicman is an unknown quantity at this point
what can hitting the tie rod do. I think when my friend was doin that side he may of hit it cause when it rain and snows, my handling is horrible. Im almost afraid to drive then. If that is the case, is there anything to do bout it?
Old Mar 24, 2002
bzrollin's Avatar
Well, if you hit the tie rod from below to try and knock it out, you are probably going to break it, which will cause sloppy steering. To check your tie rods, jack the car up, grab the wheel on the left and right sides and check for play (side to side). If you got some play, you need a new tie rod end and an alignment. If there is no play, you probably just need an alignment.
Old Mar 24, 2002
how much for a new tie rod if thats the case? hey thanx for the advice too
Old Mar 24, 2002
sorphin's Avatar
welp, all done, tho i think i need new tie rod ends now.. doh.. or else it needs to go in just a lil more, but when parked if i move the wheel side to side it's chunk chunk, ah well, guess i'll go get some and put them on when i put the camber kit on...
-ds
(btw.. i am sore as hell.. this was not worth saving $200.. eesh, and took me 2 days :/)
Old Mar 24, 2002
bzrollin's Avatar
Tie rod ends are about $30-40 each probably.
Sorphin: That noise is proably just the spring sliding into its seats.
Old Mar 24, 2002
where can get a tie rod, been searchin but nothin
Old Mar 24, 2002
bzrollin's Avatar
I found em at http://slhondaparts.com under the "P.S. GEAR BOX" heading. Part #53541-S5A-003 END, TIE ROD $32.40
You would just need the end, not the whole tie rod.
Old Mar 24, 2002
thanx man, big help. i just need to check mine out tomorrow
Old Mar 25, 2002
sorphin's Avatar
<< I found em at http://slhondaparts.com under the "P.S. GEAR BOX" heading. Part #53541-S5A-003 END, TIE ROD $32.40
so THATS what it was under.. doh... btw.. hondaautomotiveparts has it for $31.09 [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
btw.. yup, i definately need an alignment after this [IMG]i/expressions/face-icon-small-wink.gif[/IMG] my wheel is at 10-11 o'clock, but definately lower [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
pics soon of the whole car
-ds
hans.pcguy
Jul 12, 2015 12:19 PM
mrohitredd
May 28, 2015 10:03 AM
tomg
May 21, 2015 07:05 AM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
