When to have an alignment
Old Mar 22, 2002
Heylerds's Avatar
Heylerds is an unknown quantity at this point
To you guys who droped their car with springs, when did you get an alignment, right after the install or did you wait until it settled (1 week, 2 weeks..how long)?Thanks
Old Mar 22, 2002
emmagatorone's Avatar
emmagatorone is an unknown quantity at this point
Wait until your car settles.
Old Mar 22, 2002
HeartbreakkiD's Avatar
HeartbreakkiD is an unknown quantity at this point
i get allignment after install the spring one time...200 buds!!
damn!
ehhehe... now need to go with camber kit.
Old Mar 23, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
dont waste ur money in getting an alignment unless you have the camber kit,,,if you do i'd wait 3 four weeks
Old Mar 23, 2002
VanDizKo's Avatar
VanDizKo is an unknown quantity at this point
I had a full coilover kitset up 2.50" all four corners with front and rear camber kit adjustment, the good things about full coilover set up, it's actually low my car center gravity, and now my car has improved handling so much. I tested out my car in fast speed corner turning, man the handling is amazing. I am planing to upgrade front and rear strut bars and anti-swaybar to even make to the handling more amazing. Anyway, you should installed springs/shocks and camber kits at once by yourself to save money, NOTE: you do not have to adjust the camber, just install them and the mechanics will adjust them when they aligment your car, make sure you tell the mechanics you have the adjustable camber kit both front and rear. (It's easy to install, go here
01CivicSuspensionSetup) then test drive the car to feel the car handling for a day or adjust the desire height or damper if you have coilovers or adjustable shocks. After all that, go to the shop for aligment for both front and rear for $58.00, "ALWAYS GET ALIGMENT AFTER LOW THE CAR," don't look and feel the wheels of the car because you won't able to tell if the aligment is off. This not only help you to save money on tires, but it also help your car sticks to the ground for best handling. Hope this helps.
Old Mar 23, 2002
Heylerds's Avatar
Yup, it helps a lot. Thanks for the info guys.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
