Question about spring install (tie rod removal)
Old Mar 25, 2002
HP's Avatar
HP
HP is an unknown quantity at this point
Hello! I wonder if any of you that installed springs can give me some info on how to actually remove the tie rods in the front. I had the whole setup with strut and everything removed on one side as a test except for the tie rod that is stuck!! I don't wanna do anything wrong and destroy anything. I tried to look at DIY's but it just says remove and not how to remove.
Thanks!
Old Mar 25, 2002
sorphin's Avatar
sorphin is an unknown quantity at this point
Dealt with this yesterday myself.. you need a tie rod seperator (can borrow from autozone)... put it between the tie rod end an d where it attaches to the strut tower, and hammer on it *hard*, eventually it'll push in between and seperate [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
-ds
<< Hello! I wonder if any of you that installed springs can give me some info on how to actually remove the tie rods in the front. I had the whole setup with strut and everything removed on one side as a test except for the tie rod that is stuck!! I don't wanna do anything wrong and destroy anything. I tried to look at DIY's but it just says remove and not how to remove.
Thanks!
Old Mar 25, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Make sure you don't tear the tir-rod boot though. The people that installed my springs did that and I had to go back a few weeks later and waste another hours...
Old Mar 25, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
just bang it with a rubber mallet, works great dont worry you wont break it
Old Mar 25, 2002
HP's Avatar
HP
OK, thanks... I'll try with the bangin [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Otherwise I'll have to get me one of those separators.
Old Mar 25, 2002
ayzan's Avatar
ayzan is an unknown quantity at this point
spin the nut on the tie rod all the way until it is almost off. Then pound the nut from underneath with a hammer. It will take a few whacks, but it will come off. The reason why you turn the nut all the way is so that you don't pound on the bolt which will strip the bolt. The nut protects the bolt and it's easier to replace a bolt then a tie rod.
Old Mar 26, 2002
VTECpnay01's Avatar
VTECpnay01 is an unknown quantity at this point
we used a small hammer and banged the $hit out of it!! and it didnt hurt anything!!
Old Mar 26, 2002
HP's Avatar
HP
Time to bring out my hammer with brass and aluminum heads I made in school maaany years ago and never used. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Well… have to try it this weekend and see what happens
Old Mar 27, 2002
VNlilMAN's Avatar
The Standard One
what exactly is the tie rod? not what it does but what it looks like. i'm thinking its somewhere near the bottom of the strut, but not exactly sure where and what it is. any pictures of it?
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
tomg
May 21, 2015 07:05 AM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
