LED lights?
Old Mar 31, 2002
WestGaTrev's Avatar
WestGaTrev is an unknown quantity at this point
LED lights?
I was just wondering what is the difference between regular and LED lights for my turn signal?
Old Mar 31, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
led lights are brighter and will not fade
Old Mar 31, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
LED's usually last a lot long and take up less power to light up.
Old Mar 31, 2002
bhayes82's Avatar
bhayes82 is an unknown quantity at this point
LEDs are not really "brighter"... they're more intense. some can nearly blind you when looking at them directly head-on, but move it just a few degrees to the side and it will disappear. sorta like a laser... a really narrow viewing angle. you can diffuse an LED with some sort of lens, the frosted style for example, and you can see it from a wider angle, although it will be significantly dimmer than head-on. one cool possibility i noticed while messin' around with my car was that putting yellow LEDs in the rear turn signal lens still came out yellow! that's how intense LEDs are -- so i'm trying to hook some up to the rear blinker so it will blink yellow, but the lens will still remain red.
Old Mar 31, 2002
SilverCivic2K1's Avatar
SilverCivic2K1 is an unknown quantity at this point
does anyone have a link to a good led site? One that I know is ledtronics
Old Mar 31, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
do they make them to replace the 7443 bulbs? (front blinker)
Old Mar 31, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
I've seen a place that has 7443 LED replacements... somewhere online.
But also with LED replacement bulbs... the resistance on your blinker system goes way down.
I.E. Instant hyper blinker.
When I put in some replacement LED's for my rear turn signal, I had already had a DIY hyperblinker running, and with the LED's in place, the damn thing turned into a strobe light. just guessing, but it was probably around 10-15x
So now, I'm adding resistance to my "hyper" blinker to keep that speed down.
Old Mar 31, 2002
bobbyd's Avatar
HZ Engineering for L.E.D.s
themechanic
Lighting
Feb 2, 2018 09:23 PM
TiggerDX
Jun 18, 2015 01:43 PM
MamaBear2015
May 27, 2015 12:04 PM
eorlando1
May 17, 2015 11:16 AM
blackbullet
Dec 1, 2001 03:44 PM
