What is purging
Old Mar 31, 2002
JeffSpeed21's Avatar
JeffSpeed21 is an unknown quantity at this point
What is purging
i was looking at honda tuning and the N/X civic; and i noticed there was a purge button. what is purge and what does that button do
Old Mar 31, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
Linck'd
this should answer all your q's on nitrous, happy hunting [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Mar 31, 2002
speedracersong's Avatar
purging is releasing the excess nitrous oxide from the system.
the purge valve is usually located around the windshield washer or wiper.
it goes pssssst noise and looks pretty cool.
Old Apr 1, 2002
FurBall's Avatar
FurBall is an unknown quantity at this point
<< purging is releasing the excess nitrous oxide from the system.
LOOKs pretty cool? You see it?
Wouldn't that be stupid to purge, if you see it?! You're driving normally, cooling down your system, and then you decide to purge. WOOSH, you're blinded by 'smoke'...??
It's a good idea to purge, I remember seeing pics of a Civic blown to bits because he didn't purge his excess N2O.... Or was that because of a bottle warmer?
Old Apr 2, 2002
<< Wouldn't that be stupid to purge, if you see it?! You're driving normally, cooling down your system, and then you decide to purge. WOOSH, you're blinded by 'smoke'...?? >>
whos stupid enough to purge while they drive
i meant after someone uses nitrous they pull over and they purge[IMG]i/expressions/face-icon-small-blush.gif[/IMG]
Old Apr 2, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
Setup your nitrous to purge through your Z3 fender vents
Old Apr 2, 2002
pinkytoe's Avatar
pinkytoe is an unknown quantity at this point
actually a purge is for releasing the air out of the nitrous line and filling it with nitrous- that way when you hit the nitrous it will instantly kick in- usually it takes a secont to reach the motor bc the line is not purged- its kinda like bleeding brakes
h4ldol
Apr 24, 2017 08:16 PM
CBRBlaize
Jun 17, 2016 06:11 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
HondaGuru
Apr 25, 2003 05:23 PM
wh3nw0rdsesc4pe
Jun 17, 2002 12:37 PM
