- Fuel System Upgrade
- Why Synthetic?
- wiring lights
- Gauge Help, Disabling DRL Light
- Removing Trim Pieces...??
- strobes and lava tubes
- revo Questions
- D17 Tech Stuff
- Custom door panels (how to)
- OEM "Style" Fog templates - Here they are...
- a/c making a weird whisteling noise...
- question
- Anyone familiar with Turbo timers..
- Ok i have a 2002 civic coupe want to drop
- K20 Type-S Swap... in our civics???
- where,how many methods,and how much to do dashlights
- Painting Trim Pieces "Clear" or "White" Primer???
- tyc projections bulbs help!
- removing the foglight blanks
- car ramps...
- Junkyard Turbo
- compression on 2k1's....
- Help! I think I F'd up bad!
- My celica GTS 2001 seats are now in!!!
- White glass tint
- HELP~~~My transmission is FU***
- DIY Radio/Window power door open thing?
- Altezza tails leaking.. HELP
- rsx sway bar
- Short shifter kind of stiff will it loosen up with time
- HP header and high flow question
- Anyone using a EGT gauge?? NA or nitrous guys....
- Replacing my timing gear...I wanna know what kinda gain im gonna get, and an estimate on how much to
- Paint chip inside TYC projectors... HELP!
- headlight help!
- Shift knob stuck on... oops.
- Nitrous??
- changing or clearing headlights
- installing new front emblem
- anyone know. . .
- Customize Turbo ????
- What are those two metal bars in the trunk???
- anyone have a DIY for an RSX sway bar conv?
- Wiring Reverse EL gauges into stock dimmer switch
- Please read...no cat converter
- Can cut key unlock trunk release?
- intake temp monitor
- blue led dash w/pics
- VTEC LIGHT...DO IT YOURSELF???
- Nitrous
- When installing the front lip....
- replacing intake filter
- anyone have a DIY for venom 400 ?
- headlight install help
- RedLine *the reasons*
- fuel problem solved!?!?
- what parts are needed
- Red Line *Update*
- diy- transmission fluid
- REDLINE INCREASE I'LL DO IT NEED HELP
- sorry guys sheesh
- Want bigger altenator
- Shift boot sagging
- How do I install my shift knob?
- Problem with gauges...
- Anyone know how to disable the odometer?
- update: i'm ready to do my blue led dash interior, but i have a ?
- DIY: CLEAR HEAD LIGHTS
- Somebody help Netcbc install his HID kit!
- re: amp with factory alternator
- Body kit painting and installing
- DIY: Hood Pins
- need help installing face guages
- help with kaminari kit...
- Coilovers Help Please
- Front Strut Tower Bar Install
- Canadian and U.S OEM Kits
- glassing question????
- Those who have HID, Please help!!
- WORKING ON CAR NOW, NEED HELP!!!
- installing racing seat
- Anyone seen this?
- Chrome gauge rings
- BODY KIT$
- spare tire under...again....
- suicide trunk hatch......engineering problem
- Question about the tail lights on a sedan!
- Civic Convertible?
- Just bought some bottom mesh grill
- Chilton VS. Haynes. the better manual??
- Cutting plexi-glass
- H3 BULBS WITH PROJECTORS BURN OUT!!! HELP
- 2 questions regarding dash trim install
- Need Help with Installing my Shift Knob???
- another interesting shortshifter theory.....
- Crazy idea, dunno if anybody has tried this or recomends this...(1/4 mile related)
- do you have to jack up your car to remove the bumper?
- Exhaust Install
- JDM Headlight Conversion???? For people with Cleared Lights
- Help anyone (spring install)
- changing auto to a manual ?
- RedLine?????????
- please, only 300zx techies respond
- For anyone considering LED bulbs, info you should know.
- Pointing Fog Lights
- SUICIDE HOOD
- Just Cleared out Headlights
- Projector HEADLIGHTS - One is BRIGHTER?!?!?!
- Anybody using over-wattage bulbs?
- I Relocated my rear stoplight!
- Blinker relays interchangeable between coupe and sedan???
- Tire Balance Quotes...Please help.
- just a quick question about our factory exhaust
- My headlights stopped working ???
- Whats the Diffrence???plz help
- in-car laptop or rackmount mp3 and vid server
- painting a body kit....
- Tachometer?
- Uneven Wheel Gap....Shocks?
- help!!! i need a part number for a coilovers..
- where do we place jack stands for the front of the car?
- HELP! DIY valve cover painting (error)
- can this spoiler fit on the civic sedan?
- Resetting the main. req'd light
- I Read The DIY On Installing Washer LED's But....
- Installing OEM Style Fogs - Need Template
- OEM Shifter with Boot conversion..?
- DIY Hard Wire Radar Detector for LX?
- adjusting headlights....
- I don't understand hyperblinker
- Auto Trans
- Turn Signals
- Can I swap this???
- Short shifter install......
- Installing a wireless remote for underbody neons
- dimensions of trunk
- Indiglo question...Not the normal question
- civic autoX racer's thoughts about Shortshifters
- FIRST SERVICE...
- Steering Conversion Question
- DIY Hyperblinker question
- groundcontrols coilovers for 01 civic & 02 civics
- getting behind air vents?
- Dash light and gauge light bulb size?
- does anybody know how to reset the maintenance required light?
- DIY blue dash question
- How difficult to install headers?
- OK WTF!
- what's the point of...
- Head Lights
- air/fuel
- Possible to change the color of reverse indiglows?
- HELP!!!
- Zex Kits
- Engine vibration when idle
- Exhaust Question
- I chipped some paint off my bumper...
- DIY: Adding Tachometer HELP
- Honda Factory Instructions
- smells like burnt plastic
- twin canister muffler.....
- ATTN: BLUENVY01 and Others..... Question about puttin HP headers + Greddy Evo on the LX
- Removal of Rear "H" Emblem
- Need Help Installing HID Kit
- what happened to the DIY Mega Thread???
- Tire Replacement=Pro-Rated
- parking lights
- Where to drill a hole in the firewall
- injen cai
- HOW TO CLEAN AEM SRI INTAKE FILTER
- Intake Cleaning Question
- HELP@@
- Valve Cover Painting... with DupliColor Mirage System
- auto meter air/fuel gauge install???
- cai or short ram ??
- Links to other '02 Si/SiR sites...
- Updated: DIY Relocating spare tire under the car (with pics)
- Turboed Matrix info that may help with 7G Civics
- Free Air Subs?
- AEM Cold Air installation
- Piping
- Aftermarket Fog/Driving Light Install Question
- HELP ON a/c and blinker
- Do our Civics come slightly tinted from the factory?
- SQUEEKY SPRINGS? (kind of)
- NEED HELP!
- S-AFC??
- CPU chip worries
- HELP! Installing Revo SS when POP!....
- Grinding Noise...when i accelerate..FIXED!!!!!!!
- engine swap
- I Hate My Cleared + Black Headlamps
- just installed HU, now having electrical problems!
- Ok so maybe all these intakes,headers,cat-backs don't give us much but what about!?!?
- just bought 3157's but dont fit
- ps2 question
- A different type of cleared lights....
- remote start in 5-speed
- Procedure for shaving door handles?
- cat-back question.....
- non-noob altezza question
- Catalyc Converter
- seat install...
- Anyone know how to fix a SCRATCHED WINDSHIELD
- Tranny swap and head swap (as seen in Products and Parts)
- Pullies?
- custom strut bars?
- how do i install an m3 powered mirror with led?
- Can any one make a D I Y for moving your tire under your car??
- HELP ME!! SNAPPED STRUT TOWER BOLT
- Painting RS sticker for Grill?
- Horsepower gain?
- HELP!! how do you take the runner assembly off of the seats??
- how can i keep my floor mats in place...
- lets talk cost...
- racing seat brackets
- Had my car for 1 year do i need a tune up or sumthing?!
- Installing A Body Kit Correctly
- What to do?????????????
- Do I need to clear coat touch-up paint?
- questions on painting
- CUT FRONT STRUTS????
- need a lil help please
- alignment after a accident
- projection headlamps
- Light up light switch. need help.
- Headers Question...
- Tapping wires?
- Tint ?????
- 2 Throttle Cables
- B series engine swap??
- Increase in Red Line
- What Does CAI Exactly Do?
- Location of engine bolt for coolant flush???
- Window Tint Question....
- A ?, for those with nitorous.
- Painting Altezzas...
- Help with Upper Grill Install
- Another fuel question
- Returnless system...........
- DIY Relocating spare tire under the car (no pics)
- two install questions
- What Gas Should I use in My Civic?
- Some one please Help !!!!!!!!!
- Fuel cutoff=bad news
- NEED HELP !!!!!!!!!!!!!!!!!!!!!!
- Apexi V-AFC install help!!!
- need help with Headlight ? peoples....
- Stiffer suspension for 2002?
