Painting Trim Pieces "Clear" or "White" Primer???
Old Jul 5, 2002
Jc20unc's Avatar
Jc20unc is an unknown quantity at this point
hey guys just got home from the autopart shop and i bought "Clear Primer" because they didn't have "White Primer"....is that okay to use for painting our trim pieces or do i need to get the White Primer...thanks for the help
Old Jul 5, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
it will probably be fine.. but the color u paint on top of it might come out dark.. becuase u will still be paintin on basically a black surface.. i couldnt find white or clear primer.. i used gray primer.. and its just light enuff but dark enuff to make the color stay the same as on the cap..
i think gray would be best.. since white might make your color too light??? and clear might make it to dark???
Old Jul 5, 2002
civicvtec1ps's Avatar
Search and Learn
clear is no problem. it should work out good
Old Jul 5, 2002
Jc20unc's Avatar
thanks for your info...thats some pretty good logic, i didn't see gray primer either...since i have the clear i might as well try it out, thanks man
Old Jul 5, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Grey is always a best bet for painting, its a neutral shade. White will hilight whatever color you are using and black will aways burn the color. Grey will always give you the best representation of the actual color you are painting since it doesnt absorb or reflect any of the natural light. Most people use white on interior trim because of the natural darkness inside compared to outside to actually brighten up the colors when viewed from outside the car. Clear primer is good to use on an already neutral color when your going to be painting solid colors (non-metallic) or using multi process paint jobs (base coat, color coat, top coat)
Old Jul 5, 2002
dragoon's Avatar
grey will turn out the best if you're doing them silver. white makes the color a little too light, and black makes it a little too dark IMO
Old Jul 5, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
take your time homies this could turn out gtreat if you take your time (be patient ) and if anyone is near sac i will even do it for you or take you to my friendsbody shop and he will o it for less than 30 bucks if i walk in with you
Old Jul 6, 2002
RRCivic01's Avatar
RRCivic01 is an unknown quantity at this point
Yea, I got a question half *** relating to this. I was trying to pop out my trim piece in the dash where the radio is, and there is supposed to be a bracket that you push on... right? Well when I got my system installed apparently they "got rid" of the bracket and I don't have one. So, how can I get that trim piece out? Any thoughts? I took apart my car the other day and then I sat there (upside down) staring up at the mass of wires wondering where this magical bracket was... or maybe I just can't see it or get to it because my new deck is in the way... either way, I got nothing. [IMG]i/expressions/face-icon-small-sad.gif[/IMG] My friend told me to "push out the radio" but I don't see what good that would do. Sorry to invade your thread Jc20unc. But yea, what they said about the paint! I've only got a few things painted but it looks good so far.
Old Jul 6, 2002
dragoon's Avatar
yeah, try pushing the radio out
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
carid
Sep 28, 2015 10:13 AM
speedlever
Sep 24, 2015 07:18 PM
