DIY blue dash question
Old Jun 23, 2002
Unleaded's Avatar
Unleaded is an unknown quantity at this point
i need to know how many bulbs are in the cruise control/sunroof/mirror switch panel so that i can replace them with blue led's. thanks.
Old Jun 23, 2002
DukeTheNuke's Avatar
DukeTheNuke is an unknown quantity at this point
Hey, don’t try to replace the LED if you are not an experienced electrician.
I fryed my wires trying to replace them and it cost me like $200 bucks for the dealership to fix it
Old Jun 23, 2002
Unleaded's Avatar
i'm removing the little stock bulbs and replacing them with wired led bulbs. this is simpler than you think. the leds will be powered by 12v source in which i will tap into. also, does anyone know how to remove the amber films behind the ac/defrost/recirculate buttons? i see 2 screws holding the back but i can't seem to pry it out after removing the screws. or do the buttons just pop out from the front? thanks.
Old Jun 23, 2002
DcatStylee's Avatar
DcatStylee is an unknown quantity at this point
I'm pretty sure someone did a very good DIY on this.
Old Jun 23, 2002
bhayes82's Avatar
bhayes82 is an unknown quantity at this point
unleaded: the buttons pop off, just pry hard from one side...
also, as for "...wired led bulbs. this is simpler than you think"... not really. have you considered the fact that LEDs have a VERY TINY viewing angle? incandescent bulbs throw light out in every direction, LEDs do not. they won't be as bright as you think. and if you're wiring in your own LEDs (as opposed to ordering LED bulb-replacements, which is probably gonna run in the $100's to replace all the bulbs in the dash), are you aware that nearly all LEDs have a maximum voltage of about 4--5 volts? that means soldering on a resistor to EACH LED. i wouldn't call this "simple".
Old Jun 24, 2002
Unleaded's Avatar
bhayes, so the buttons just pop off huh? thanks. in regards to the led's, i'm not wiring my own led's, they come prewired. all i have to do is connect one wire to the power source and the other to the ground just like any other bulbs. what do you think?
Old Jun 24, 2002
bhayes82's Avatar
sweet! if that's the case, then it makes it a lot easier... where did u get those? how much?
Old Jun 24, 2002
PeArlHoNdA's Avatar
PeArlHoNdA is an unknown quantity at this point
ya for real...changed my dash to blue but stayed away from LED's cause of the "electrical" aspect of it but ur way sounds REAL simple
PeArLhOnDa
Old Jun 24, 2002
Unleaded's Avatar
got them from ebay, they come in many colors. prices range from $4.50 each to $5.00. i got 5 with one free!
Old Jun 24, 2002
PeArlHoNdA's Avatar
bro can u post some sizes or somethin? cause my gel sheets look good BUT LED's would be great, keep us informed cause if there is no electrical ill do it, thats what kept me away.
PeArLhOnDa
Old Jun 25, 2002
Unleaded's Avatar
i'm still waiting for my reverse indiglo to come before i tackle this project. i will definately post pics when everything is completed - stay tuned.... oh, i'm currently driving with a small flashlight on my guage cluster at night cause i've got no dash lights at all so i'm definately anxious to do this mod
Old Jun 25, 2002
Kermit's Avatar
Kermit is an unknown quantity at this point
Defenately post some pics of this mod when your done, sounds really kewl. Good luck man!
Old Jul 11, 2002
BlueLightning's Avatar
BlueLightning is an unknown quantity at this point
well thats cool i though of that tooo.. but wasnt sure if it would work.. but since you did it i guess it does work..
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
SidCivic
Nov 24, 2015 08:36 AM
BootyDo
May 7, 2015 04:46 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
