Help anyone (spring install)
Old Jun 27, 2002
Silver2002's Avatar
Silver2002 is an unknown quantity at this point
I just read the diy yourself on installing springs on the 7th gen civics. It said to make marks on the front to make sure you keep everything aliagned. Does anyone know how to reallign them if you didn't do this? Big problem!!!
Old Jun 27, 2002
VNlilMAN's Avatar
The Standard One
good luck getting it back on... it might throw off the alignment...
did you take off both or still have one on? on the top mount, look at the peice right on top of the rubber. one side of it has a small gap and the other side has a big gap.(sorry i know i'm not explaining it too well). if you have the other strut, see what side the small gap goes on and try to work from there... after you get that the other top peice has an arrow, just match up the arrows. and the 3 bolts only go in one way... sorry its hard to understand but ya the only other option is to play with it, turn it lil by lil till it fits.
Old Jun 27, 2002
2cute's Avatar
2cute is an unknown quantity at this point
You shouldn't have to mark them. They should already be marked. On the strut mount (if I remember correctly) there is a white line. If all else fails put the strut mount in and adjust the strut accordingly. It has been a very long time since I did my springs but they were already marked.
Old Jun 27, 2002
VNlilMAN's Avatar
The Standard One
mine were marked too but they were off...
Old Jun 29, 2002
Silver2002's Avatar
Ok, I got everything installed and the original problem with noise when I turned is gone. The right front side makes too much of a loose noise when I hit the slightest bump. I'm still figuring this is a spring alignment problem so I'm going to try and reset the right one more time. Does anyone know anything about Tech5 springs? I installed them and the look/ride seem pretty good so far.
Old Jun 29, 2002
VNlilMAN's Avatar
The Standard One
tech5? never even heard of them. do they have a site? how low of a drop? hows the ride, etc...
Old Jun 30, 2002
Silver2002's Avatar
The ride is great so far. They lowered my sedan 2 inches. It seems pretty even front and back. Maybee I'll get a picture this weekend for you.
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
Ccoop87
Jul 9, 2015 03:26 PM
