Location of engine bolt for coolant flush???
Rep Power: 0 Location of engine bolt for coolant flush???
Hey all....
Does anyone know where the heck the engine bolt for releasing the coolant lives??? I'll tried looking at the owner's manual, but it's basically worthless.
PLEASE HELP ME!!!!
Thanks.
SilverRazor[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
PLEASE HELP ME!!!!
Thanks.
DIY King
Rep Power: 395 Somewhere near the bottom of the radiator I think? I'de like to know too...
I want to put in some Redline Water Wetter for the summer with my antifreeze...
Rep Power: 0 There probably is a big white bolt type thing at the bottom of the radiator. It should be big enough for you to turn with your hand. YOu'll know it when you see it. That is where it has been with my previous hondas but haven't looked on the vic. I suspect that you'll find it there.
Rep Power: 0 <<------#2 is the drain bolt, so it would be on the right hand side of the radiator, looking at the car from the front and apparently, accessible from inside the front of the engine bay.
Rep Power: 0 I'm referring to the drain bolt on the ENGINE. The plastic one on the bottom of the radiator is pretty much in the open and very accessible. If anyone has done this before, let us know. THANKS AGAIN.
-Silver
-Silver
1 Post
Rep Power: 0 On my acura integra and previous civic, the drain bolt is located on the block behind the exhuast manifold. That is what you need to open to get the coolant out and do a proper flush.
I'll check a little later on to see exactly where it is located in our civics.
Support your local 81
Location: In the land of milk and butter, Massachusetts, US
Quote
[hr]Originally posted by: Grey
I want to put in some Redline Water Wetter for the summer with my antifreeze...[hr]
your right....its a wing nut. Just make sure the engine is cool, that coolant can be real hot.
BootyDo
05-07-2015 04:46 PM
