- Question on cleaning engine through throttle Body
- how many amps should i be getting
- trunk popper
- Transmission letter lights
- Where is my SCS connect?
- MT TB same as AT TB ?
- Touch up & Accessory Painting
- clutch wear, for all the MT people out there...
- Mugen knob?
- Si cluster
- Size of Tailights
- gauge installation
- Stock Head-unit
- 05 Civic Help...
- 2000 Accord EX 4cyl probelms?
- OEM Exhaust Tip question
- air fuel ratio
- Power window regulator motor
- Burnt out bulb
- will this header bolt on to our D17?
- installing front seats????
- I Need Tranny Help Asap
- Replacing the ECU add HP ?
- Need your help ASAP Please! Car wont move!!!
- Is it possible to switch from NA tune to N20 tune with Emanage on the fly?
- I need major HELP
- best cam for making HP?
- Engine severely shakes [SOLUTION FOUND]
- Need help installing coilovers!!!!
- 03-04 civic lights fitment?
- Help w/door lock assembly
- Safc
- mods to make power at 8k?
- Horn Replacement Wiring for 2 Horns
- CD-Changer
- Help removing oem suspension
- Dent Removal question?
- Ester based synth oil???
- RS front lip install
- [HELLLLPP] No Audio Power@!!
- Where is it????
- Custom IM
- to bore or not to bore TB?
- Sparco Install
- Fiberglass
- Exhaust gasket question
- Power Steering..
- Need some brake help...
- Rsx-s mufflers
- Greddy E-01
- How do i fix SRS light?
- DIY squeeky clutch problem HELP FAST
- LX to EX exhaust
- 04-05 headlights
- need help - 01 to 03 gauge cluster swap
- What size is the Engine Block Coolant Bolt?
- exhaust temp
- clutch smell/ intake noise
- anyone with 2k1's ever install Intermittent wiper controls?
- nuespeed tie bar, problem and question
- throttle response
- Headlight alignment on 2004+?
- strut bar
- LOW Beam/ HIgh beam
- HIDs into projectors
- Fuel Pressure Regulator
- Question on Alternators
- ECU questions from a Noob
- Spark Plug Cleaning
- DIY 04-05 Clear/Blue Turn Signals
- Can 2001 to 2005 Civics be Jimmied???
- Rev-Matching
- Tuned vtec controller
- venom 400 problem
- Simple aero dynamics and wind resistance question
- Have you greased your clutch today?
- just installed header and car runs like shit
- VP to EX exhaust?
- ratteling noise under the hood
- Carbon Fiber Hood problem.
- o2 sim questions
- Help installing AC Air/Fuel Ratio Gauge
- S2000 Gauge Cluster In 7Th Gen Civics?
- My Motives
- 03+ Cluster
- HID Kit on '05 Reverb
- clutch
- Black out headlights... question
- d16/d17 ???
- bore and stroke ?...
- Anyone have details on changing Timing Belt
- When did you first change your fuel filter?
- valve stem install
- keyless entry
- Steering wheel removal
- removing taillights
- Power Shifting
- Sealing my tail lights?
- venom 400
- Vid – my vic getting dyno tuned! Screaming!
- DIY: First time changing brake pads
- p1298
- Qs about altezzas
- Sparkplugs
- 3rd brake light
- removing ac and power steering
- how do I make a 15 or 14 sec car
- Transmission Problems
- DIY RSX seats
- HELP: Question about unit of some sort by gas tank
- HELP: removing kit glue / double-sided tape
- ground kit material
- VTEC on an LX?
- delete plz
- 3rd gear grind...
- How to remove the shifter panel?
- Cluster Needles Not Moving!???
- exhaust rattle fix?
- what trannys will bolt up to d17?
- Cluster swap help
- DIY Help??
- Digital fuel gauge??
- tach install
- Honda dealer installing aftermarket clutch and flywheel for 10.00
- What is fuel relay?
- DIY Ground kit facts
- Shop/Service Manual for 03 Civic Ex
- Beep Beep
- window conversion
- When Brakes are applied.
- Question for A/C Techs?
- Help installing gauge
- vtec controller help
- Aftermarket Rims/Stock Suspension?
- How long to change Mobil 1 oil/filter?
- Anyone ever change their differntial fluid?
- Hellllllllllllppppppppppp
- radiator fan broken...car overheating
- Bought a new part today
- The D17 VTEC controversy (solved).
- Do they make a 2-step for our car
- o2 question
- Gear Ratios
- Removing WW 3 piece spoiler
- All those that have swapped Steering Wheels..please read!!
- Shifting Question
- Help with pulling head.
- Thermal vs Standard??
- Problem w/ dash lights
- 2 Step
- Five bolt hub retro/switch
- 60/40 bench removal
- does this mean that... (regarding VTEC engagement)
- My HKS Exhaust
- Disconnected Guage Cluster
- Rev Question
- Another Jack Question
- Crower Rod?
- Removing Carpet In A Civic (need Help)
- Control Arm bushing removal and ES replacement
- remove 04 door panel
- tach impulse pickup?
- strokin' the D17
- Do you have sunroof dimples?
- What is up with Hondawerx.com? O and I have a lower grill Q too!
- 2.25 homemade exhaust (pics) Now with video
- HELP! P0740 code problem
- Change Manual Transmission Fluid
- friend needs help
- How much are we talking?
- damn power lock....
- gahh what was that thing about the vtec light...
- stock AUTO civic dyno?
- Sparco hood pin install
- B16b engine question
- How do I remove the rear deck of a 4 door
- Help with Grille-Tech Grille?????
- what is this thing?
- Rear Deck Idea For Rattles (Pics Included)
- WTF? Some one has to know whats up!
- 01 civic lx overheating like crazy...please help
- installed header, now problems
- Dx vs Ex exhaust
- Ignition Problems!
- im looking for an 80mm shift light that will fit in a gauge cluster
- Popping When I turn....
- Paint off side skirts
- What would you prefer?
- Turbo + Cat = ?
- heated mirrors for civic???
- Oil changing FAQ
- Blinking "maint reqd" engine light at startup?
- Check engine code
- How does this really work?
- Wiring Spoiler Brake Light
- i need your help guys!!!!
- help with hyperblinker
- Should I Buy A Performance Chip???
- What are the differences between E-Manage and VAFC II???
- Engine Cleaner: Sea Foam Product actually WORKS!!!
- Injectors and Tranny Flush For 350?
- civic type R shift knob opinions
- cluster swap question
- Is this performance computer worth the money?
- Shops to take out stripped nut
- Anyone with Prinout of Recall for seat rocking back and forth
- 04 Rear Bumper on an 02.
- PRO PERFORMANCE CHIP HElp?????????
- 10w 30???
- Final Drive Ratio
- Oil change
- molding oem kit
- something interesting about our cars
- exhaust sound?
- Dome light/Power lock problem
- rsx front end conversion
- Ex manifold on dx
- Are there any settings I can play with on my new VAFC II???
- check engine light
- Manual window handle
- PCV Replacement
- Help!
- Suspension torque specs
- Sunroof Wiring Diagram for Alarm
- D17 Riders
- Is this really a "test pipe"...or....
- headlights
- lambo door install
- How hot does header get?
- Took off my tb spacer and...
- Removing 'windshield trim' pieces?
- Where is this...
- AN Specification Information
- Where does the.......?
- REMOVAL: outside window weatherstripping (molding)
- HID question! Plz help me!
- So this might be a stupid question....
- dropping a d17a2 into....
- Experiment RSR **.avi video added**
- Turbo vs. Nitrous...need opinions
- Will a test pipe....???
- Gauge Cluster, printed board...
- D17 N/a
- Diy headlights blackout
- Exhaust smell, rich or lean?
- em2 -> RSX e-brake swap
- Need Turbo Parts
- Question.
- Engine seems to be outta wack(Tuning)
- OEM Spoiler: Broken screw
