trunk popper
trunk popper
i remember a while ago people were able to do this, with the truck opener from like a 98 accord or something , are people still doing this, and is it possible on a 05 lx sedan, as well , is it possible to get a controller from an accord and just change out the key and the signal to match your car or whatever to just make it look like it belongs, rather then with an aftermarket alarm?
no, it will not work with oem alarm. but it will bolt in. I did it on my coupe, and im gonna order one for my gf's sedan this week.
Circuit city did mine on the 02 sedan recently. Bolts right on, controled with my viper alarm by pressing two buttons. The relay it came with didn't work, they had to use another one and hook it up. Paid around $40 for install, $35 for the part off handaaccessories.com
thats not bad at all, but why wont it work with an oem alarm, cause im having lockjack put on , and just want something simple to open up the trunk
not just the remote, the factory alarm in general doesnt have an available channel. The install took me 20-30 minutes, the hard part being hooking up the relay and running the wire to the trunk.
why not use from an accord then? damn i didnt know it was this easy and so many times does it seem to come in handy, so what kind of remotes can i hook it up to ?
you can use the Canadian Acura EL pooper, security moduel, and relay and you will have it without installing an alarm, but you might as well get an alarm since you have added security for almost the same money.
Originally Posted by profuse007
youll need an extra channel thatll generate (-) pulse to trigger popper via a relay.
btw, the circuit city guy prolly didnt know how to read the relay diagram thats on top of the relay.
you would think so but OEM diagram either use 1,2,3,4,also 5 (if spdt relay, trunk popper relay has 4 pins (spst)) or just plain coil and pole diagram.
the bosch type relay uses 85,86,30,87,87a(spdt relay), they dont look at he diagram on top of the relay. you will be surprise, alarm installers are so used to the bosch-type relays but when theyre given something slightly diff, just cant seem to figure it out.
Originally Posted by SkipBarber
i doubt it, they just dont have anything that'll plug into it. So they used something with a plug and wires. If they can use any relay, they understand a diagram, since the numbers are also listed on the oem relay.
Originally Posted by runner1738
point of it is just to stay oem, not lower the value or the car or anything like that, but we would still be using 2 different key chains then? any part number?
I will get you some part numbers as soon as i come back from classes.
awesome that is actually what i wanted to know, looks like ill be looking into the acura el then. thanks so much you guys, i cant wait to get this done
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
Skunkone
Sep 24, 2015 04:38 PM
