The D17 VTEC controversy (solved).
Old 02-25-2005
Once boosted now i-VTEC
C Orndorff's Avatar
C Orndorff is an unknown quantity at this point
For a long time there has been a debate on this over the D17A2 VTEC.
Some people say it is a regular VTEC that engages at 4500RPM
And there are others that say it is a VTEC-E that kicks at 2500-3000RPM
Well I did a lot of research and tore apart my engine to prove my point (and to do some other things that I will post in the DIY section)
This is it this is the FINAL ANSWER
We have VTEC-E that kicks at 2500
I use to think that are VTEC kicked at 4500 until I read up on it. I went to Honda and copied all the cam profiles and tore apart my engine to come up with this answer.
Here is a link to my old post on VTEC all Photos are there. Look at page 3 for the smoking gun.
Here is a link to honda that says d17's have VTEC-E http://www.hondanews.com/CatID2015?m...asc&archives=t
http://www.7thgencivic.com/forums/sh...1&page=1&pp=15
http://www.7thgencivic.com/forums/sh...1&page=3&pp=15
C Orndorff is offline
Old 02-25-2005
flotsamm's Avatar
Wow.. thats alot of work to prove a point, good job. I always thought my car surged with a tiny amount of power at around 2800 rpms, perhaps this is my VTEC kicking in. I can hear my engine make a different sound also when this happens.
flotsamm is offline
Old 02-25-2005
solo_rider's Avatar
solo_rider is an unknown quantity at this point
i have a hx so i always knew i had vtec-e
solo_rider is offline
Old 02-25-2005
I knew ex had vtec-e already it says right on the honda site when I priced my 02 civic.
Now this is getting crazy. Vtec still kicks in at WOT right? Just at lower rpms?
gearbox is offline
Old 02-25-2005
C Orndorff's Avatar
VTEC hits about 2500-2800 full throttle. Or about 3000 if it is half throttle. It has to hit at least at three; otherwise you will suffocate the motor (because only one valve is open).
Old 02-25-2005
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1's Avatar
4drcivic2k1 is an unknown quantity at this point
Suffocate the motor?
4drcivic2k1 is offline
Old 02-25-2005
DOHC i-VTEC TiMEX
aznboysrfr's Avatar
well ... that's what -I've- been saying since the beginning ...
K20a3 vtec is the same as our vtec ... the only difference is that we have only one cam. vtec engages at 2200 rpm under hard throttle, up to 3000 under light throttle. same as the k20a3 ... http://www.hondata.com/techk20general.html
if you check out their vtec cam, it looks very similar to our vtec cam
aznboysrfr is offline
Old 02-25-2005
That is an excellent picture. Our rocker arms are situated the same. The rocker on the left simply cracks open to prevent fuel puddling behind the valve.
Old 02-25-2005
If I set the vtec engagement point to 2800rpms with a vafc, will it still only engage at wot and when the engine is warm, oil pressure high enough, etc? So it's safe to do?
gearbox is offline
Old 02-25-2005
C Orndorff's Avatar
As long as you have proper fuel tuned in, you will be fine.
Old 02-25-2005
C Orndorff's Avatar
Yeah a engine cant breath well a high RPM's on only one valve. Here a link read up.
http://www.leecao.com/honda/vtec/sohcvtece.html
Old 02-25-2005
Yup it's been tuned on a dyno, just wanna make sure setting to a certain point won't hurt. You know I tried to set the vtec point hi one time like 4500k rpms and the car wasn't feeling so good between 3-4k rpms. Maybe that's what you mean by suffocating.
gearbox is offline
Old 02-25-2005
Sorry, All Unrelated Posts Will Be Deleted. Let's Keep On Topic.
gearbox is offline
Old 02-25-2005
C Orndorff's Avatar
Thanks
Old 02-25-2005
Why is my vagina bleeding?
nindoo's Avatar
Cool will this info help make my car faster?
nindoo is offline
Old 02-25-2005
_Viper_'s Avatar
Hey Honda has a new selenoid that will make it kick in instantly
_Viper_ is offline
Old 02-25-2005
I set my vtec to 2800 rpms and if I'm acelerating slowly from a stop to around 3200rpms, I feel a power increase as soon as the vtec light turns on at 2800rpms. It's like pressing the gas more even tho I'm not. But it is noticable to me.
gearbox is offline
Old 02-25-2005
psychotic_z's Avatar
psychotic_z is an unknown quantity at this point
Honda is so tricky with there stock ECU tuning that because of tuning alone that is why the Integra GSR makes all its power at high rpm’s, why did they do that you may ask. Because too many consumers complained about torque steer at low rpms for the first year of its production.
Sorry bro... for a statement like this and a few others from your other "SOHC VTEC Explained" thread, I don't buy it...
BTW, our EX's do not get the gas mileage of HX and DX models solely because of our ECU tune
Besides, there's a few points you really can't explain.
Ok... so if you say we have VTEC-E that engages at 2500 RPM... What causes the change in sound at around 4900 RPM indicated?
-We do not have secondaries in our intake manifolds (correct me if I'm wrong there, I'm assuming we don't)
-We do not have two VTEC solenoids for both a 2500 RPM profile change AND a 4900 RPM profile change
-Nothing else in our engines, besides a profile change, can cause the sound change. There is little or no power difference because there is not supposed to be. VTEC activation was never meant to kick you back in your seat; it was designed to be a smooth transition, as it is in our cars and all other grocery getter Hondas.
WHY is this such a mystery?
We've known what our camshafts look like for a while.. a few people on this forum actually tore into the engine and put in regrinds before they put on wHaCk bling-bling body kits and chromed wheels
Anyhow, you can see from the camshaft: one intake valve is open all the time, the other is slightly opened to avoid charge puddling... When VTEC activates, the second intake valve opens to the height of the first intake valve until the pin is released and VTEC is "deactivated".
Where did you find this 2500 RPM number?
psychotic_z is offline
Old 02-25-2005
What? I think you swapped your wording around..
Old 02-26-2005
zachgeyer's Avatar
hum wow
zachgeyer is offline
Old 02-26-2005
I don't believe the set rpm either. It also depends on how far you press the gas. I've seen it engage anywhere from 2200rpm to 3000rpm. It varies with throttle, although it's only supposed to engage when the gas is floored. I'm confused.
gearbox is offline
Old 02-26-2005
goodtimes's Avatar
aw this is two much but good jod findin the info...
goodtimes is offline
Old 02-26-2005
valdezin az's Avatar
valdezin az is an unknown quantity at this point
I just got a v-afcII for my 01 civic ex does anyone know why my check engine keeps coming on and why the engine bogs at 4000 RPM its killin me I get get it right help me out
valdezin az is offline
Old 02-26-2005
mine works perfectly
http://www.7thgencivic.com/forums/sh...d.php?t=169767
gearbox is offline
Old 02-27-2005
Old 03-02-2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
So if VTec engages at 2500ish rpm then my VTec is always engaged except in 1st from a stop. At each shift my rpms are around 3K so therefore VTec never disengages? I must be missing something...
bobsagator is offline
Old 03-02-2005
A lot of people are missing something, so don't feel bad.
Where VTEC engages on these motors is generally worthless to even try to change, because it does very little in terms of power gains.
Old 03-02-2005
I'm tried changing it a few times, and the car always feels like something is wrong. I say just let it do what it's supposed to.
gearbox is offline
Old 03-02-2005
bobsagator... Yeah, don't feel bad - there's a crap load of technical misinformation all over this forum that people spread daily. The VTEC engagement isn't at 2500 RPM, either.
In general, take what you read here with a grain of salt.
Old 03-02-2005
Anyone know if this is right or not?? Stock engagement
gearbox is offline
Quick Reply: The D17 VTEC controversy (solved).
