strokin' the D17
Old Feb 22, 2005
dnbguy86's Avatar
dnbguy86 is an unknown quantity at this point
strokin' the D17
With much debate, i think i've decided to bore over my D17. I can get all the work and labor done cheap since i know the builder. Now my question is, would this in anyway set any codes that im unaware of ? this is prolly an obvious question but i suppose my auto tranny wont last as long either...
also, has anyone ever done this type of modification and if so what were the results. If i can im gonna try to bore it to a 1.9. or 2.0L
Old Feb 22, 2005
TheSmuggler's Avatar
If you bore to big you'll weaken the sides and be forced to sleeve,
Old Feb 22, 2005
hotrodcivic2004's Avatar
my civic has no boost
any stroker kits out there for our cars?
Old Feb 22, 2005
^^no
Old Feb 22, 2005
dnbguy86's Avatar
Obviously it'll be a custom setup. or would it just be eaiser to drop in a k20, but then brings up the prob of wiring the vtec and blah blah blah. which one would ya'll choose and give reasons as to why you would pick a certain way than the other.
Old Feb 22, 2005
^^Wiring the Vtec? When you swap the k20 your going to be swpaping ecu's also, theres no wiring up of new vtec lol. If you HAVE the option, go k20. Swap or boost most will tell you
Old Feb 22, 2005
dnbguy86's Avatar
well if i can, i want N/A dunno why just do. anywho, i think itd be cheaper to go with the strokin idea but itll make less power than the k20, but it also costs more so theres a conflict between my decision here. I dont want a badass racecar or nothing, id just like a lil extra power for my dialy driver without sacrificing reliablity!?
Also, i have an automatic transaxle, so how hard would it be to swap in a 6 speed outta an rsx type s. ive heard it just swaps right over to the d17 block, but it could be bad info.
Old Feb 22, 2005
Hmmm, reliability well thats k20 there, i mean it's STOCK you cant get much more reliable than that lol.. N/A trust me you'll want k20 lol
Old Feb 22, 2005
dnbguy86's Avatar
Well, i guess the bad part to that is that itll will obviously void my factory warranty.....so i dunno, any other ideas why or why i should stroke it or get a k20 ?
Old Feb 22, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
You will be much better off swapping
Swapping=~175whp for $4500 installed
boring=~135whp with I/H/E if you are lucky (i am sure that you would gain tq, but not enough to make it worth it)
Old Feb 22, 2005
I just don't thinking boring it out alot (especially up to 2.0) is a good idea, because that would thin the walls substantially... then you'd have to sleeve it... meh... honestly, k20 would be your best bet =)
Old Feb 22, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
The 6 speed from an RSX won't fit a D-17. The engine sits th other way around. Even if it bolts up, you'd have 6 reverse gears and one very slow forward.
I'd do a k20 swap. Best daily driver option, IMO.
Old Feb 22, 2005
bgoetz's Avatar
I'm lost
Old Feb 22, 2005
bgoetz's Avatar
I'm lost
Ok just learned to read I'm good now
Old Feb 22, 2005
bgoetz's Avatar
Bad info, you can swap a 5spd from a D17
Old Feb 22, 2005
ajhdragon's Avatar
7thgens official a$$hole
i'd say mesure the side walls and stuff and maybe you can modify a stroker kit from a b18 or something. i have a spare d17 block if ya want it. sell it to ya cheap but im sure shipping will be $$$.
Old Feb 23, 2005
Logan3024's Avatar
Would make alot more sence to lower the weight of the crankshaft and use some high compression 75mm 11:5:1 pistons, light weight rods and a custom camshaft.
Old Feb 23, 2005
Leets's Avatar
Leets is an unknown quantity at this point
I'll be the first to tell you to keep the D-series... not because the K-series sucks, but just because I've always preferred the underdog Honda block. However, I wouldn't recommend stroking the motor. Your dealing with a block that was originally designed for 1.6 liters of displacement. First of all, you WILL have to resleave the block if you want to actually torture it the way Honda engines were designed to be. Next you will have to either A.) have a new crank designed or B.) have some custom counter-weighing done on the stock one (which I'm not even sure is possible). There's a lot more to boring an engine than just making the cylinders bigger. You have to take into account rotational inertia, compression, etc. There are ways to make it work, but it sure won't be reliable as a daily driver. To get it to work flawlessly takes immeasurable amounts of R&D which is why companies don't invest in stroker kits for "unpopular" engines. If you still have the factory warranty, then keep it, especially if this is your only daily driver. I'm sure there will be plenty of parts for the d17s, but those are still years down the line. After all, there was a time when you couldn't buy anything for the d16/d15 either. Just save up your money, take full advantage of the warranty, and keep on eye on what gets developed.
Old Feb 23, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
where do you get it for 4500???
Old Feb 26, 2005
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
yeah, I was wondering the same myself...I think you'd be lucky to get the engine alone for that much.
Maybe he's considering that you're personally doing the swap yourself
Old Mar 7, 2005
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
true honda has the k20a for 5600 and the k20a2 for 4200 with everything you need to swap. but i doubt it has the motor mounts plus there will be labor costs unless you can do it yourself.
Donahue
Sep 8, 2015 09:00 AM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
lyanreindecker
Aug 20, 2015 09:15 PM
CivicLude
May 12, 2002 08:01 PM
bo0sT
Apr 3, 2002 09:11 PM
