Is it possible to switch from NA tune to N20 tune with Emanage on the fly?
Old Mar 19, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
Ok if I got pnp head, bored TB, a cam plus emanage and tuned. Then slapped a wet kit on. Would it be possible to run a different program on the Emanage with 3-4degree timming retard so I could safely run a 75shot(maybe100) and have enough fuel to maintain proper A/F ratio. If so could I switch back and forth between these two programs? I have read a lot of FAQ's about emanage, but most are for boosted app. So with that said from what I have gathered maybe this could be done with a Laptop and the support software?
Old Mar 19, 2005
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
1. i have no idea about emanage
2. i'm an avid 75 shot user with pnp head and cam regrind and you'll love it, but there is no need to retard the timing. if you get 2 step colder spark plugs you'll be fine. i use ngk v-powers.
3. the only way you'll run a 100 is with forged internals. the stock ones can handle it for a couple shots then boom. i've seen it done on a crx.
4. as for tb i don't know. gearbox had maxbore do his tb and it ran bad n/a. you might ask him.
Old Mar 19, 2005
Redline04's Avatar
How long have you been running the 75shot? How often do you spray? Have you had it tuned? How do your plugs look? Any track times?
Old Mar 19, 2005
i've been running a 75 since last summer and yes i do it often and so far no problems at all. as far as tuning. none but i'm wanting to have it dyno tuned real soon. i have yet to go to the track though. and how do the plugs look? what do you mean?
Old Mar 28, 2005
tougas01's Avatar
tougas01 is an unknown quantity at this point
if u go 75 it's 2 degrees retarded, if you go 100 it's 4 - Usually
if you dont go the 2 way
carid
Nov 7, 2015 01:46 AM
Misfit2613
Jul 30, 2015 09:49 AM
cukaracha
Jul 17, 2015 05:48 PM
krazykoncepts
Jul 14, 2015 01:55 PM
Bounddyy
Jul 8, 2015 11:22 AM
