Can 2001 to 2005 Civics be Jimmied???
Old Mar 9, 2005
_Viper_'s Avatar
Lets say i lock the keys ive heard our cars cannot be jimmied with a device is that true or has anyone been able to unlock the car without keys if so How...
2000 points to who has the answer...
I called a tow truck company and they said that they do it with their eyes closed...
I undid a panel and the rod that is attached to the button to lock and unlock is protected by a piece of plastic...
please help
Old Mar 9, 2005
ciVictoria's Avatar
I don't think this would be a good idea for telling people how to open up cars without keys this might just encourage stealing cars..
Old Mar 9, 2005
InOvAtStyL's Avatar
Never Too Wide, Never Too Extreme
InOvAtStyL is on a distinguished road
it can VERY easily be jimmied. After my accident, my doors wouldn't open cause I have shaved handles, so they jimmied it. Very simple, but there's a trick to it. Once you figure out the trick, it's simple.
Old Mar 9, 2005
_Viper_'s Avatar
No it wont you still have to start them ..and there are transponders in keys..
I want to know how to get in my car if i lock my keys in the car..
Besides a brick in the window
Old Mar 9, 2005
nickm748's Avatar
im guessing this is going to get locked
Old Mar 9, 2005
Ichiban's Avatar
Ichiban is an unknown quantity at this point
It is hard to lock the keys in the car. The drvier side door won't lock if the door is open at least on the EXs this is true.
Old Mar 9, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
yeah but i have a friend who managed to lock himself out by leaving the keys in the trunk, LOL
so its possible and funny!!!
Old Mar 9, 2005
CivicsRdBest's Avatar
I've been told that it is possible. They tried to fix it so that you'll have a harder time compared to older Civics, but if you really want to, you can.
Old Mar 9, 2005
_Viper_'s Avatar
Ok How???? and yes I locked them in the trunk before
Old Mar 9, 2005
tacheon's Avatar
tacheon is on a distinguished road
please help
Answer: Yes it can be jimmied. However, I assure you that no thief will use this method as it is easier and more discreet to use a screwdriver to the lock cylinder. The tow truck driver can use one of 2 methods to open the vehicle. One method involves pounding a plastic wedge into the A-pillar beside the door. Then using a rod to pop the lock with a rod. Another method involves using a specially shaped "slim-jim" device to pop the door lock linkage from the bottom of the window and around the latch protector. This is no secret as tow truck drivers must release the parking brake to tow the car if the driver isn't around. Theives won't use this method because it's too conspicuous.
All vehicles on the market excluding some very high end luxury vehicles can be opened by non-destructive methods.
Old Mar 9, 2005
tacheon's Avatar
Also Civics older than 2001 can be opened by popping the window out of the frame. I won't detail that method here, but it can't be done to 2001 (corrected) and newer cars as long as your windows are rolled to the top.
Old Mar 9, 2005
Al Gore FTW's Avatar
jdmtytedoridori
audio/alarm shop here told me that 04 and up has cable lock mechanisms, not metal rods. i dunno though
Old Mar 9, 2005
civicdragster02's Avatar
civicdragster02 is an unknown quantity at this point
I locked my keys in my car and I used a thin piece of metal
and pried out on the top of my door carefully and slid a hanger
down from the top and lifted up on the door lock was no problem
didn't leave any marks either
Old Mar 9, 2005
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
Yeah but has anyone locked their keys in their car while it is running? Well yes I have done it! not in my vic but in my '99 Accord. I was with two friends and I called AAA to pop the lock. It was embarassing but funny at the same time!
Old Mar 9, 2005
LiKEaFeRiO's Avatar
Tow truck drivers now carry bags for the first method you mentioned.
They open up the door at the pillar slightly then insert a bag.
The bag has a pump attached to it so they just pump and create space without vehicle damage. Almost the same device doctors use to measure blood pressure. Last they insert the metal rod and lift the door lock.
I've locked myself out of my car 3 times now.
Each tow truck failed at jimmying the car and had to use the bag.
Old Mar 11, 2005
jdmtytedoridori
I have done that!! my keyless entry locks the car a few seconds after you turn it on, and so i turned the car on with the driver door open, and even though our civs dont lock with the door open, it locks and so i closed the door and went to open it and it was locked. car was idling for like 2 hours lol
Old Mar 11, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Just to add my $0.02 in, I just can't see how you will ever lock your keys in your car by accident. You cannot lock the driver's door by pushing the plunger down when getting out of your car. It will not let you (unless this is an 03 / 04 civic thing). You have to use the key to lock the door, and even then you have to do so when the door is closed. So when you close the door and realize you don't have your keys, you open the door and get them. Lastly, if you have auto locks you need the remote to open / close them. So if you close them with the remote, you should have it to open them. You can lock the keys in there purposefully but you do so by closing the drivers door, going to the passenger door, pushing the plunger down, leave the keys in there and lock the other door you crawled in from (non driver door).
Old Mar 11, 2005
komodomichie's Avatar
komodomichie is an unknown quantity at this point
Actually I believe that you can lock the drivers side door by pushing down the button, but you have to first hold the outside handle open, then push down. That will allow the button to be locked and you can close the door (not sure if you have to hold the handle open while closing the door) but I have done it before. A lot of older cars have the same mechanism.
Old Mar 11, 2005
LiKEaFeRiO's Avatar
^^^That is correct.
You just pull up on the driver's outside door handle and push down the lock.
Everything locks too and you just close the door.
Old Mar 11, 2005
fullgrown's Avatar
<---- I am really this short in person!
fullgrown is an unknown quantity at this point
i remember a tow truck guy opening my car by climbing down the near the right axle with a flat head and just poke something and the driverside door would open. don't know what he poked, but it worked.
Old Mar 13, 2005
paradoxblue's Avatar
lol ye sif u hold open the handle and push the auto lock down it will lock. BUT if the cars running u cant do this.
i played around to see how i could lock myelf out.. only way i have found is IF i lock them in the trunk or drop them in the car. heh
Old Mar 13, 2005
anibal's Avatar
anibal is an unknown quantity at this point
Easy way to avoid locking keys is to carry more than one car key with you. The civic comes with three keys, 2 standard keys and one valet ket. I need to carry too many keys all the time so i divided them in two sets and have a car key in each one. Also, you can lock the driver's door by pulling the inside door handle, not just the outside one. I know cause i do it all the time and never leave my keys locked inside the car
Old Mar 13, 2005
manahoonie's Avatar
i've accidentally locked my keys in the trunk once! i was down at a school they district wasn't using (budget cuts) working on rattles from subs. i was messing with the rear latch, and disconnected the cable that runs to the trunk release up byb the driver. i left my keys on the floor, and shut the lid.
IT WAS A PAIN IN THE **** reaching back between the sub box (2-12") and the wall!
Old Mar 13, 2005
manahoonie's Avatar
/\/\ was before i got keyless entry. now, i just use keyless entry to lock and unlock my car everytime. for the trunk, i unlock the car, and use the lever by the driver.
Old Mar 13, 2005
mdwalsh80's Avatar
mdwalsh80 is an unknown quantity at this point
It takes AAA < 20 seconds to open our cars 01 ex. in through the key hole. and car automatically locks if you use remote to unlock and walk away or even put keys in ignition car will still lock. Maybe mine is defective or something! Since nobody else can lock theirs in the car.
Old May 14, 2005
civic_sedan's Avatar
civic_sedan is an unknown quantity at this point
yea if u unlock ur door via control and don't get in within a minute or something or 30 secs maybe?....it re-locks...
Old May 14, 2005
jdmtytedoridori
damn n00bs.....
Old May 14, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
I do the same thing. But some how every time I only have one key on me I accidently drop the keys in the driver side pocket when I reach for the phone or wallet or chapstick. The best way for the tow truck drivers is to use the rod to unlock the doors.
civic_gt
Apr 19, 2015 08:15 AM
twtron
Apr 17, 2015 12:09 AM
dano2005
Apr 14, 2015 01:58 AM
CapYoda
Nov 11, 2001 05:17 PM
liljoe
Nov 4, 2001 01:27 PM
