valve stem install
Old Mar 6, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
valve stem install
How do i install valve stems?
It seems pretty obvious. I slide One end in, slide the other rubber grommet and 2 bolts into the back of the bolt and tighten down.
My question: Is there any oil or lubricant your supposed to use on the rubber grommets or valve stem hole?
I know your supposed to lube the edges of the wheel before the tire goes on.
I used to change tires at a small shop. I never did new valve stems.
Old Mar 7, 2005
2k1civic.com O. G.
any honda tech's know? I guess i should just leave it to the wheel shop to do once they mount my tires. I dont even know the torque specs for the bolt.
Old Mar 7, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
You got metal stems or rubber ones? The metal ones you just push through and tighten the stem on from the outside of the wheel. I didn't lube the rubber seal when I did it, they haven't leaked yet.
Rubber ones you probably just shove in the hole.
If you're talking about the core, then you need a valve stem core tool. Its a funky little screwdriver type thing that you just put over the core and unscrew it, then screw the new one in.
Old Mar 7, 2005
2k1civic.com O. G.
yea its a metal one with 2 rubber grommets to seal each side of the wheels hole for the valve stem.
Mine seems to tighten from the inside of the wheel. The 2 bolts and washer pushes the 2nd rubber gromment in and holds the hole thing in place.
Im just gonna leave it to the wheel shop becuase i dont know how much to tighten the bolts.
Old Mar 7, 2005
BOOSTLESSD17's Avatar
cant boost cuz it'll wreck the name
BOOSTLESSD17 is an unknown quantity at this point
Use locktight if doing yourself so the nuts dont back off
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
159
Jul 5, 2015 09:54 PM
Reverb2005
Jun 26, 2015 06:22 PM
blacklud
Apr 13, 2015 06:15 PM
Jeff
Bolt-on Engine Performance
Nov 25, 2001 10:01 AM
