Need help installing coilovers!!!!
Old Mar 18, 2005
Mr.honda's Avatar
Mr.honda is an unknown quantity at this point
I can't find an actual DIY on installing adjustable coilovers.With the spring so much smaller and all the extra parts I can't figure it out! Does anyone know what all the set screws are for or how it all goes together?
Please help!!!
Thanks Josh
Old Mar 19, 2005
suthrninca's Avatar
suthrninca is an unknown quantity at this point
Please help!!!
Thanks Josh
It's not difficult. The set screws go in the sleeve to keep it from moving around. The spring goes over the sleeve and the sleeve goes over the shock/strut. The sleeve needs to slide al the way down to the stock spring perch. As far as installation, I can't give details. I just started by unbolting the upper shock/strut mount and figured it out from there. If you are removing stock springs, you will probably want to borrow a spring compressor from autozone. And if you like having even tread on your tires, you should also get a camber kit and alignment asap.
GolNat
Jan 12, 2021 09:06 PM
Misfit2613
Jul 30, 2015 09:49 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
