clutch wear, for all the MT people out there...
Old Mar 22, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Ok so what i the deal with downshifting, if you dont put it in the red how much does it wear, people say if you rev match it doesnt wear on the clutch, but does that mean if you dont rev match when up shifting it wears, i blew out my last clutch in my saturn, no that i got the 7th gen i want to not wear the clutch any help...
Old Mar 22, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
your clutch is gonna wear either, its not like rev matching won't wear it at all, maybe slower, but either way, its gonna go eventually. You can make it last longer by driving less vigorously. I think what wears the clutch the most is downshifting to a lower gear at a very high speed (aka shifting to 3rd while going 80 or something like that). Since there's no way of "maintaining" your clutch parts, just becareful while driving and every clutch should last you a long time. Plus, if you wanna push your car everyday, get a high perfomance clutch...don't push your stock one, that one stinks when it gets pushed too hard, lol.
Old Mar 22, 2005
flotsamm's Avatar
Just try to use it as little as possible and never leave your foot on the clutch. Try to let it out as fast possble without looking like a jerk. lol
Old Mar 22, 2005
Zzyzx's Avatar
Autocross Junky
Ok, heres the low down on revmatching.... as in why if you rev-match there is little to no extra wear on the clutch... and it should also inform you that as long as you up shift right there is also little wear on the clutch...
Lets brake the cars drive train in to two parts, the engine + fly wheel and the Clutch + Transmission. We've broken the system down to these parts because. The engine and fly wheel are allways spinning at the same RPM, and the Clutch and transminssion are allways(when in gear) spinning at the same RPM...
Now, Say the engine/Flywheel are spinning at 3,000 RPM's in 5th gear. With the car in gear, the Transmission/clutch will also be spinning at 3,000 RPM's. If you were to Down shift to 4th... As you disconnect the Tranny/cluch from the Engine/fly wheel, the engines RPMs start to drop (your off the gas) when you shift to the lower gear, Due to The Gearing on the car, the Tranny/cluch 's RPM's now jump to 5,000 RPM's If you were to simply let go of the clutch, you would now have an engine/flywheel spinning at some where less then 3,000 RPM's and a transmission/cluch that is spinning some where in the 5,000 RPM range.... when the Flywheel/clutch finaly start to grip eachother, the transmission would instantly try and force the engine to jump to 5,000 RPM's... This is simmilar to droping the clutch when trying to launch the car... Meaning you get tons of clutch wear (Due to clutch slippage), and you can break other parts too. BUT!!! if you were to revmatch, you would Blip the throttle to bring the Engine/Flywheel up to 5,000 RPM's and then release the clutch, you would have a flywheel spinning at aroudn 5,000 RPM's and a Clutch spinning at around 5,000 RPM's.. and when they came in contact, since they are both spinning at approximatly the same speed, there would be Very little if any clutch slipage = Little to no extra clutch wear.
For up shifting, you dont need to rev match simply because as you increase speed, the RPM's the tranny will be at in the next highest gear will be lower then what they are at in the current gear, so as the engines RPMs naturally drop when the clutch is pressed, it acts as sort of a natrual revmatch... so aslong as you arnt too slow or fast with the clutch, there should also be little to no clutch wear on an up shift.
Remember, A good down shift should be heard and not felt! and so should a good up shift.
Old Mar 22, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
your clutch will last alot longer in the 7th gen then the saturn clutch will. May sound like a n00b/fanboy comment. But its the sad truth.
Old Mar 22, 2005
Al Gore FTW's Avatar
jdmtytedoridori
very good explanation, i was wondering about this too.
Old Mar 24, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
downshifting to slow down is bad idea. brake pads are way cheaper than clutch and tranny parts. and you can do brakes yourself really easy. takes about an hour if you don't have to lift up one wheel at a time....lol
Old Mar 24, 2005
ragingSPAM's Avatar
I just burnt my tongue
if you rev match with a heel-toe and u can do it without riding ur clutch than it will help keep the clutch from burning out fast...but nonsense reving while clutch being engaged is just stupidity
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Roman Rembacz
Jul 16, 2015 12:30 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
