OEM Exhaust Tip question
Old Mar 21, 2005
JCiv03's Avatar
Hi. I have an OEM exhaust tip and i was wondering how to install this. There's a bolt that goes on from the bottom, do i need to drill a hole into my exhaust tip so the bolt can go through? I'm not sure because I looked at the installation guide, and it mentions nothing about drilling a hole.
Also a friend told me that drilling a hole in the exhaust tip will be bad because the head will make the metal weak, and ultimately enlarging the hole. Is this true?
Here's a picture of what the tip to get a better idea of what i'm talking about.
Any help would be great.
Thanks!
Old Mar 21, 2005
tacheon's Avatar
tacheon is on a distinguished road
Do not drill a hole. It clamps and holds the tip in place. Just tighten it such that the tip won't come off.
Old Mar 21, 2005
JCiv03's Avatar
Oh, so the bolt should definately hold it in place? I really dont want to fall off. I'm just a little paranoid.. lol
Old Mar 21, 2005
tacheon's Avatar
Yes. If you drill a hole, you will cause a point for corrosion to occur on your exhaust pipe. The pipe is aluminized steel. If you drill it, you penetrate the aluminum and accelerate corrosion.
Old Mar 21, 2005
juzthewy's Avatar
juzthewy will become famous soon enoughjuzthewy will become famous soon enough
a hole will lead to a possible leak, which will lead to loss of compression and a blown piston
Old Mar 22, 2005
tacheon's Avatar
How on earth will a hole at the end of a tail pipe lead to a blown piston or anything else for that matter?
Old Mar 22, 2005
skapunk82's Avatar
skapunk82 is an unknown quantity at this point
dumbazz i guess the hole on the end of my hayame exhaust for the silencer is what makes my car slow huh.....not only loss of compression but windlag too.....once again dumbazz
Old Mar 25, 2005
silverem2's Avatar
yea, and adding a axle back will cause the welds on the intake to go and you will have to replace the piston rings you fried
Old Mar 25, 2005
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
Hey JCiv, can you post pics after you installed them?
Old Mar 26, 2005
12sec elcamino's Avatar
12sec elcamino is an unknown quantity at this point
I hear that dumping break lathe shavings in your oil will prolong engine life and keep the ring seal good for hundreds of thousands of miles, guess its like extra lube for all moving parts or something! Thus no broken piston, this is only for juzthewy. He has that special car, ya know!
Old Mar 26, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
A hole after the muffler shouldn't affect anything... I mean... your exhaust vapors come out a hole after the muffler don't they?
Old Mar 26, 2005
Okay, put the tip on, put on the screw and tighten, done. No drilling.
Old Mar 31, 2005
JCiv03's Avatar
Sure, i didnt see your request until now (thursday). I'll take some pics of it when i come home on the weekend.
Red_Chaos1
Jun 21, 2015 01:12 AM
PierrePierre
Jun 17, 2015 06:22 PM
juror
May 26, 2015 06:35 PM
mugenca
Apr 16, 2015 12:15 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 8, 2001 12:14 AM
