Sparco hood pin install
Old Feb 20, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
Now how the hell am i supposed to install these hood pins? The DIY is for a different set of pins.
Injen
Old Feb 20, 2005
injencivic's Avatar
i got these from robearracing.com... They are not the "spring" type pins.
NeonImpact has the same pins as me, but i cant really talk to him since hes always busy.
Thanks,
Injen
Old Feb 20, 2005
gangrel138's Avatar
gangrel138 is an unknown quantity at this point
The first step is to find a good mounting point for the pin(the long piece). Mine are mounted fairly far out to each side. Then you have to drill a hole for each and use the included locking nuts to keep the pin from moving. You will drill a hole in the hood for the pin to come through and then adjust the locking pin(part with the ring) before screwing those into the hood. And you might want some grease to help the process since it will take some time for the pieces to settle in and work smoothly together. It takes a hell of a lot of adjustment and I just had mine done professionally so I could blame someone else if something went wrong.
I'll take some pics and hopefully post them for you in the next day or two. I've gotta say they look pretty good and I really needed them since the metal my hood latch connects to was bent and causing my hood to rattle violently at 60+ mph.
Old Feb 20, 2005
injencivic's Avatar
please do cause i am not exactly sure how to mount these since its a different set from the DIY.
Injen
Old Feb 22, 2005
injencivic's Avatar
bump
Old Mar 5, 2005
gangrel138's Avatar
Sorry for the delay on the pics. My computer at home crashed and I can't bring my camera into work for security reasons. I'll try to get them on my friends computer tonight or tomorrow.
Old Mar 5, 2005
DAQIUN's Avatar
DAQIUN has a little shameless behaviour in the past
good
Old Mar 6, 2005
gangrel138's Avatar
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
fvckbg
Jul 7, 2015 07:08 PM
cgavin1
Jul 7, 2015 07:10 AM
robbie374
Jul 7, 2015 02:56 AM
