removing ac and power steering
Old Mar 5, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
If I was to do so, what would I gain?
Old Mar 5, 2005
civic01vtec's Avatar
hard steering and hot summer days.....that is about it
actually.........maybe about .005 secs in the 1/4 from weight reduction
Old Mar 5, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
less parasitic drain should create more horses but the only way to find out is to dyno it before and after. try it and let us know
Old Mar 5, 2005
QBoi's Avatar
have fun sweating from the hard steering and heat
Old Mar 5, 2005
xX03EXx's Avatar
Sweetest Dude on 7th Gen
The small gains would not be worth it. The only way I would ever do it would be if I told someone I was going to race them then I would put them back in shortly after. But I don't race so I would never do it.
Old Mar 5, 2005
Blahman2's Avatar
I hear there is a way to wire them to a switch. So you can deactivate them when you want to. But I have no idea.
Old Mar 5, 2005
QBoi's Avatar
deactivating them would not result in any gains...
Old Mar 5, 2005
Logan3024's Avatar
Not if its belt driven. Many new cars lately have been getting rid of the belt driven a/c and powersteering, and replacing it with electric ones. The new mercedes 500 (e or s class) has an electric a/c and it stays on in the summer 30 minutes after you leave the car and turn it off. So if you wanna run and get a bit to eat and its hot outside your benz will be chillin with the a/c on waiting for you.
Old Mar 5, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Have fun sweatin cuz of no P/S or A/C? What a bunch of lil babiez! Sack up!
Old Mar 5, 2005
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
i have no ac anyways, and i pull the power steering belt whenever i do any spirited driving, way better whell response
and i live in FL lol
Old Mar 5, 2005
TheSmuggler's Avatar
lmao i might be taking my a/c out lol
Old Mar 5, 2005
streetglower's Avatar
I am positive mercedes still uses belt driven ac systems. I work there and havent heard of any car doing that. All mercedes are front engine and have the one or two drive belts driving everything.
Als it is usually the radiator fan staying on after 30 min. of shutoff to aid in cooling the engine down faster.
Old Mar 5, 2005
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
i was thinking about doing it. i would like to hear what it does
Old Mar 5, 2005
QBoi's Avatar
yeah, you won't be saying that if you can't turn fast enough to dodge a deer.
Old Mar 5, 2005
ncirom2003's Avatar
my brothers ITR was on the dyno at 210 whp then he removed power steering belt and got it to about 216 whp. you have half the horsepower so do the math and theoretically its not worth it. the most ur gettin it 4hp so dont bother
Old Mar 6, 2005
I live in Diego...aint no deer around here. LOL!
Old Mar 6, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
I noticed a difference so I just left it off. It used to be hard in parking lots and around corners in the city(moving slow), but once your moving it's actually easy to maneuver. Before I left it was actually easy all of the time. Either I got stronger or the fluid evaporated inside the lines. Which is not good. I was told as long as the lines have some fluid to keep everything lubed you will have no prob. So I suggest every now and then to hook it up so you can get some fresh fluid in there. I need to do this when I get back. Other than that I would say it definitely revs up faster without it. I am willing to sacrafice comfort for performance. Not everyone is willing, so it's up to you.
Old Mar 6, 2005
Well said. You get a much better feel for the road without P/S.
Originally Posted by Redline04
I noticed a difference so I just left it off. It used to be hard in parking lots and around corners in the city(moving slow), but once your moving it's actually easy to manuver. Before I left it was actually easy all of the time. Either I got stronger or the fluid evaporated inside the lines. Which is not good. I was told as long as the lines have some fluid to keep everything lubed you will have no prob. So I suggest every now and then to hook it up so you can get some fresh fluid in there. I need to do this when I get back. Other than that I would say it definitely revs up faster without it. I am will ing to sacrafice comfort for performance. Not everyone is willing, so it's up to you.
Old Mar 6, 2005
Redline04's Avatar
I'm trying to lose another 100-200lbs. So the ac is probally gonna come out when I get back. It's gonna be a little hot mid summer in Louisiana, but oh well winter will come eventually. How much do you think I could get for a brand new ac system if I sold it. Car only has 7000miles on it and the ac has probally only seen 24hrs of actual use.
Old Mar 6, 2005
Blahman2's Avatar
Why would I want to dodge the deer?
Old Mar 6, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Just to touch on the Benz Ac system. Its my understanding that its an option that enables you to have solar panels on the top of your car. The solar panels take in the light energy make it into electrical energy and power the fans on your car, I don't think they power the ac. Its designed to blow air around and help cool the car off at a programed time before you come back to the car. The BMWS have this as well, my old 91 525i had this feature but you had to wire it in yourself. When you left the car you programed a time you would come back and the fans would kick in a certain time before you came back. Benz just took it one step futhur with the solar panels.
RIPSAW
Nov 6, 2015 04:36 AM
vvr210
May 31, 2015 08:02 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
