10w 30???
Old Feb 14, 2005
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
10w 30???
went to get an oil change today. i have 30k on an 01 lx. its not under warrenty anymore so the guy said to put in 10w30. is that good? and when i check the oil where is it supposed to be on the stick? 2nd dot?
Old Feb 14, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
manual says 5w20.
I use 0w20 ;P
Old Feb 14, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I would run 5w20.
I personally run Redline synthetic 5w20.
Old Feb 14, 2005
VegasJones's Avatar
VegasJones is an unknown quantity at this point
i ran Mobil 1 0-20 when I was up in Utah, but it's a "little" warmer down here in Vegas so I went with a little bit thicker Mobil 1 5-30
Old Feb 14, 2005
streetglower's Avatar
you are fine. I run 10w-30
Old Feb 14, 2005
12sec elcamino's Avatar
12sec elcamino is an unknown quantity at this point
10w30 is fine, remember synthetic is little thinner, I use mobile1 10w30 since 1st oil change.
Old Feb 15, 2005
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
10w-30 isn't offering you a benefit that you can't achieve with 5w-30 or for that matter a 5w-20.
The 20 weight oils are well built and you might want to use the new Mobil 1 5w-20 that will be coming out shortly. It's going to replace their 0w-20.
I'd dump the 10w because it's thickness is only making it harder to pump oil at start up. It does not offer additional protection at temperature. A 5w-something is preferred.
I use RL but I'd also use M1. If you're concerned with thickness you could run a couple of quarts of 5w-30 and the balance with 0/5w-20. Nice brew.
Old Feb 15, 2005
2K1Civic17"Gabe's Avatar
I have used 10w30 for 90,000 miles. Car runs better than new it seems. I also use synthetic. But it works just perfect. I change oil every 3,000 even w/synthetic as well.
Old Feb 15, 2005
doubledeuce2k2's Avatar
if you live in a cold area, i would be a little more concerned. as said above, at operating temps there is no benefit. but for cold starting, a lower (5w) rating will help lubricate the engine quicker. also synthetic is thinner, so in cold you will have no problems with lubrication with a 5w20 or 5w30 syn. oil.
you can do the freezer test like my buddy did. put a cup of dino oil and a cup of synthetic oil in the freezer over night. then try to pour each the next morning. dino oil is real thick, thats what your car is trying to pump out when it gets well below freezing.
Old Feb 15, 2005
so in 120 degree summers, it is good for me to use 10w30? It gets hella hot here. I have always used that.
Old Feb 15, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
10w-30 would be ideal for vehicles with over 100k miles or of that matter.
but 30k isnt a lot, i would suggest using 5w-30, 0w-20, or 5w-20 (which honda recommends?). it also varies on your climate of location to decide which oil is better to use.
i run 5w-30 all the time and im in california.
Old Feb 15, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
I use Mobil 1 Full Syntehtic 0w-20(5w-20). I also use the oil K&N Filter. I changed the oil today.
Old Feb 16, 2005
I live in Florida so 10w works for me. I can understand if you live in Maine and its exremley cold, but for this motor only having four quarts and as high of rpm the motor has to turn all the time I feel that 10w is a good all around oil for a mild climate.
Just my 2cents though!
Old Feb 16, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Honda warrenties stop at 36,000 and I use Mobil 1 5-30
EJC98civic
Apr 20, 2014 04:10 PM
xRiCeBoYx
Lighting
37
Sep 1, 2010 10:19 PM
civicpapi
Jun 16, 2010 10:42 AM
pnoyster2k1cvic
Nov 10, 2007 04:36 PM
Perfectcivic
Feb 15, 2002 05:15 PM
