switching oil grades
Old Jun 16, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
On my 96 ex I am running 5w 30 to factory specs, if I want to go to 10w 30 will that cause problems. My reasoning is that I am leaking oil and the heavier grade will help a little?
Another question can you mix them both, say you have 5w 30 and need to add a quart of say 10w 30 will that cause problems?
Old Jun 16, 2010
ronaldo9's Avatar
Re: switching oil grades
I've switched to 10W30 on my 2003 civic because I thought that would mitigate my oil burning. It didn't solve the problem but nothing bad happened to the car. Still ran great only it was harder to start in the mornings and gas mileage went down a bit. I've also added differen't grades as I was low in oil and only had one of the other. Nothing happened and it still drives great. I just need to do more frequent oil changes to make sure I"m not too low. FYI i can go about 2500 miles before I need to add a quart. I have 136,000 Miles on the car.
Old Jun 16, 2010
BlueEM2's Avatar
Whachya lookin at?
On a 7th gen they recommend using 5w20 but it's better to use 5w30. Not sure about 6th gens but don't go too heavy. I'd try 10w30, don't mix them, that's a waste of time.
Old Jun 16, 2010
civicpapi's Avatar
6TH GEN 5w 30 is spec. Anyone use stop leaks?
Old Jun 16, 2010
BlueEM2's Avatar
Whachya lookin at?
Never use stop leak. It plugs up all the small passages and restricts flow, possibly damaging the engine. Fix the issue rather than hide it.
RIPSAW
Nov 6, 2015 04:36 AM
Star1967
Jun 8, 2015 04:23 AM
nickeynick
Apr 27, 2015 01:23 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
JoeB16
61
Oct 16, 2003 07:58 PM
