i need your help guys!!!!
my friend drives a 2001 honda civic ex..and he needs to replace his air conditioning filter....who knows where that is locted??????
reply as soon as possible!!! thanks!!!
You have to take the glovebox partway off, so it sits down on the ground or almost. Than you will see a black box, and you can pull the first filter out by pulling I believe. Than there is a second one to the right of that, that you can get out after the first one is. There is a DIY around here, let me link you. Its pretty simple hold on a sec
cant find it, sorry. But thats what you do. There are 2 screws under th glovebox, take those off, and open the glove box (after the screws are off) It should fall, than you should see the black box looking thing. It is very simple. good luck
Turbos, Engines, Chassis and Suspension Tech
You don't need to unbolt the glovebox. Just take the little tabs out of the back of it and it will swing all the way foward. Then take the little cover off of the black thing behind it, it just snaps out. The filters will be in there. Pull the first one straight out and then slide the other one over and out.
nufc
Legal Questions and the Law
Jun 21, 2015 09:57 PM
