- Diy : Sonar Tails Painted!!
- I need help with my shift knob and my head lights
- Tokiko shocks release date for 03-04 models.
- Need a CAI, for an 02 Ex AT, Any Adive
- Tail light Assy
- Auto oil change
- Tranny Problem
- AEM CAI to short ram?
- Anyone needs to know how to take off anything from interior? Ask me!!
- Which is a better exhaust?
- Why would an Engine Misfire when accelerating on a winding onramp.
- Remote UNlocking, hatch separately???
- blacking out the headlight housing
- Question about Transmission Cooler install
- Clutch Suggestions Needed!!!!
- Airbag question
- Throttle Body Question
- Any advice for exhaust?
- Adjusting Headlights need help
- gauge cluster dimensions
- Doughnut won't fit on Kami. header. Please help...
- large magnet 04 civic
- Anyone got a detailed diy for this?
- I need your opinion???
- ATF vs MTF
- stupid question!!!!!!!!!!!!!!
- Dumb Question<----Here
- Pinout For 14 Pin Connector On Stock HU
- my left rear window wont roll down
- reducing backpressure
- Help!!!!
- 01-04 civic interiors panel for sale on ebay
- Fast Blinkers
- SRS Module
- Kamikaze header questions and answers
- Does our ECU reset the Apexi SAFC2?
- Fog Lights DIY????
- Vtec on my EX seems dosn't work???
- fuel pump install help?
- lambo doors pistons
- Idle Noise When Turning Wheel
- Check engine light when turning...anyone?
- Crank Pulleys
- Throttle Body Bore??
- auto to manual conversion...BOOYA, its DONE.
- I need some help...
- about ex heads swap to an lx
- Question about Torque Wrench
- A/T excusion removal help
- Can anyone help, I stripped my nuts!
- short ram intake
- cig wire splicing (important)
- Installing new clutch and flywheel!
- Whistling sound...
- i hope people respond to this one
- maint req at 53,000
- properties of aluminum tape?
- oem body kit installation
- Final Drive
- An interesting swap question.
- S&B cone filter measurements
- 2500 Mile Trip Towing My Motorcycle.
- o2 sensor problem (HEADER)
- Should I bore out the diameter of my header's gasket??
- pulling the headlight..possible w/o taking off the bumper??
- [HELP!!]Drive Light Blinking
- vtec head swapped into an LX been done before???
- rca's on 01 ex
- 93' DX w/ oil on plugs
- '04 guages change?
- Noises on a brand new civic
- Headlight aiming
- rattling
- Just a question about a clutch.
- CEL Question
- weird sound
- B16A [jdm] vs. B16A2
- tach install prob....
- making 02 EX into AWD
- O2 Sensor extended
- ebay "speed chip"
- Skunk2 Coilover Creaking and Poping when turning wheel
- A/C paneling
- New intake setup
- Noise from axle?
- k24 in EX?
- Maintenance Light
- I need instructions for removing the stick
- water in engine f**k
- Check Engine Light HELP!!!!!
- Exhaust Scrapin
- Roof Liner?
- Fast turn signal
- Check Engine light for brake fluid?
- stereo and removing
- DIY Headlight Black Out
- Door Handle Painting
- k20a2 head fit d17?
- Weird rattle only on right turns??
- Will this 01-02 Civic RS Front Grill Fit an '03 LX?
- Honda vin #'s
- Smog Q&A
- Headlight problem
- Headlight help =\
- K&N FIPK II Fitment?
- Oil lube and filter...? What's Lubed?
- a n00b question on spark plugs
- Spoon Front lower bar
- Replacement light bulb
- throttle cable
- caliper painting quick question
- using safcII + injectors in general?
- frosty
- question about turbo
- Question regarding doors.
- High beam wires?
- VTEC Lobes
- Honda protects me from my own CD Player
- Power windows instalation
- Intake Opinion
- vtec to i-vtec conversion<--fantasy?
- Front and rear crank seal leak
- Maps/Sensors/VafcII/Wiring/VTM
- Unorthodox Racing Underdrive Crank Pulley
- air bag 'H' emblem removal
- Help with exhaust
- O2 sensor problems
- another engine oil thread
- Is a HUB required for aftermarket steering wheels?
- Someone explain why we need coolant circulating the throttlebody.
- What gauges look OEM? (RPM gauge needed!)
- Car Parts
- CD Player Destruction!
- ---Need Help With Cigarette Lighter---
- stock clutch question
- megan racing high flow cat
- How much does the stock battery weigh?
- intake air temp
- Powersteering Fluid
- VACUME LINE?? where is it help!
- 2005 HX has VTEC??
- MAP Sensor and VAFC2
- best shift for peak hp
- How to replace rear speakers
- why NOT to use dino 5w20 oil!!!
- need a favor
- installing struts
- i need help
- D17 Intake Manifold Conversion
- remove dashboard?
- Rad Hose size
- safty first
- New Distributor - Now Long Cranks and Engine Light
- Noob Word List
- Heat shield
- tuning the engine
- lx/ex intake ?
- bad throttle cables
- I know this may sound kind of stupid but...
- any specific order??
- Fyi!
- Hardwire radar detector DIY
- K&N Air Filter
- need TSB printouts!
- anybody ever install Sonar Halo Headlights?
- Removing sideskirts that are glued down with epoxy
- How much can we deck our heads?
- Auto Power Window Switch...
- Drive Right CarChipE/X
- Question about my new cold air intake
- Coupe / Sedan Exhausts
- AEM CAI info
- just a simple question i cant find
- very good find
- Need some quick help installing my hayames...stripped bolt...
- 03 bodykit on a 04 civix lx coupe
- whited out my headlights last night
- iPod car charger
- Power mirror wiring question?
- short shifter
- Air Intake question (more than standard question)
- Spark plug wires
- Clutch Help PLz
- Grrr Metal
- Is this worth it?
- cutting/rolling fenders
- wiring for tyc angeleye/halo
- 2000 accord v6 chip?
- The best way to turn off battery?
- Painting Springs
- Just installed Air Intake and now a problem
- Question about the RS*R ExMag GT-II series catback
- ebay "speed" chip "OH MY 20+ HP" rofl
- VAFC II install and tuning prices
- DC2-R seats
- Clutch make squeaky noise
- front bumper clips
- Help!!!!
- battery dies....need help solve this problem
- Int. gear Lighting
- Transmission fluid level -- help!!!!!
- VAFC II install
- my problem about jacking my car~~
- Painting Nitrous bottle
- Odometer abnormality
- DX LX vs. EX
- help me tune vafcII
- Clearing Headlights: Check List
- Remove Resonator ?
- Whatever happened to Exospeed Racing?
- changing air filters
- Autometer Pro Shift lite install? Coil?
- Performance exhaust tuning tip.
- DIY: Garage door opener - move it to cig lighter!
- $$$ for E-Manage maps!
- Best possible performance parts for ze Civic 04+
- Thoughts on the coolant bypass mod after 3 days.
- ANyone ever stick your intake in the freezer for a few hours??
- Trouble releaseing key
- Any way to reset the Main't Req`d light?
- which is which
- Stock Radio and FM modulator
- Thinking about custom intake
- altezza in oven temp.
- Grease on upper strut mount
- little info
- painting methods unleashed
- Throttlebody Bypass Mod- Gains?
- 1 to 1 ratio for dyno pull
- I think my axle is breakin@@@@@
- Learn about intake systems
- Need help on Booty Call thingy
- H.I.D. mounts for Telly
- Foglights?
- new 04 civic 4dr ex auto, need power mods
- Motorized rear seats?
- e-manage question
- AEM AIR bypass cracked
- Help! in my civic all the lights are off
- new ECU..do i need to reflash KEY?
- AEM CAI instructions?
- paint lip kit costs
- Suicide Doors
- Need help with tie rod bolt!
- AUTO tranny slipping cause of vafc
- Angelina - Lovely Girl from Eastern Europe
- Break in period
- Check engine light on
- oil filter removal made easy
- How much water is needed to cause hydrolock?
