93' DX w/ oil on plugs
Old Sep 12, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
Unhappy 93' DX w/ oil on plugs
I just got done repainting my 93' DX but i accidentally let it sit for a while without starting it because the gas went bad and i figured that if i was going to have to go through the trouble of restarting it i may as well wait till everything was done. SO...4 months later i go to check the plugs and spray some starting fluid, i noticed oil ALL OVER the plugs. Is this normal from it just sitting for a while and oil seeping in from time? or is there something wrong?
Someone told me it was normal it's just that since it sat so long it didnt burn off a little at a time like it usually would. Instead it just pooled up a little at a time.
Thanks!
Old Sep 12, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
It's the seals on the spark plug holes. I know on the 7th gen, each spark plug hole has it's own seal, on some other cars, they're all connected to the valve cover gasket. Just replace the seals and you'll be fine.
Old Sep 12, 2004
ohiojosh78's Avatar
thanks!
RIPSAW
Nov 6, 2015 04:36 AM
tock172
Jul 21, 2015 06:25 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
silverdevil
20
Jun 2, 2007 04:42 PM
JoeB16
61
Oct 16, 2003 07:58 PM
