installing struts
Old Aug 28, 2004
ecpx's Avatar
ecpx is an unknown quantity at this point
installing struts
okay i know this has been asked before but i searched around and couldn't find any info... i actually need to change both of my OEM front struts and i was just curious how hard of a job this was and what the procedure was. any information would be awesome. also if anyone has their OEM struts for a 01 civic laying around and wants to sell them, please hit me up with a PM or a post on here.
thanks in advance.
Old Aug 28, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Hard if you are a noob...also, you could literally kill yourself if you F*&K up with the spring compression...
Old Aug 28, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
how could u kill urself with the spring compression?
Old Aug 28, 2004
its not that hard at all
Old Aug 28, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
search in DIY
Old Aug 28, 2004
tacheon's Avatar
tacheon is on a distinguished road
The strut assembly is under enormous compression. It must be clamped with a spring compressor for removal and installation. If you clamp it incorrectly during the uninstallation process or don't clamp it at all, the energy from the spring will severely injure or kill you. Only do this if you know what you are doing.
Old Aug 28, 2004
xam's Avatar
xam
not really that severe, all u have to do is lay the strut assembly down, and put your foot on top of it and unscrew the bolt on the top and POW presto the whole assembly is dismantled and u can just put it back together with the new shocks and BOOM your done
Old Aug 28, 2004
i knew that.. i was being sarcastic.. when i did mine i got a loaner spring compression from autozone... basically u open the clamp and attach it to the spring... mines had a nut i had to turn to so i just used the air gun to turn it.. but i had two of em so one on each side of the spring.. key thing to doing it is u go little by little going from on clamp to the next
Old Aug 28, 2004
tacheon's Avatar
You obviously have no idea of the energy which is stored in those springs. I should post pictures of my mechanic friend with titanium pins going through his fingers. His finger shattered when the spring compressor slipped. And this guy does this on a regular basis. Your advice is going to get somebody killed.
Old Aug 28, 2004
Yah, someone is going to die in the near future trying that foot on the spring technique... You are much better off just having a mechanic do it, or if you are that strapped for cash, take the whole spring and strut set up off, leave it intact and then bring it to a shop where they can use their pneumatic spring compressor to remove the strut assembly.
Old Aug 28, 2004
Havok2k1's Avatar
Wicked Pissah Admin
http://www.7thgencivic.com/forums/sh...d.php?t=155272
It's very easy, even for a suspension noob.... We put a set of hayames and teins in both Grey's and Mystic3030's car and it was a cake job.... Air tools are your friend....
Also, we took the springs out for one set (teins). It wasn't that bad of compression on the springs. We had two people working on them. With a spring compressor, its a two minute spring removal. Without, it was a 15 minute spring removal.......
Good luck...
Old Aug 28, 2004
haha.. air tool is my best friend... but then again.. i have an electric impact gun
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
