making 02 EX into AWD
Old Sep 10, 2004
pyrofoam's Avatar
Love doesn't exist, only blood.
pyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trusted
i dunno if this is a retarded question, but, i've been thinkin about this for a little while. and havent really been able to find much on it. can the awd from a CRV be used?
Old Sep 10, 2004
abmerop18's Avatar
Jam out with your clam out.
not gonna happen
Old Sep 10, 2004
pyrofoam's Avatar
why not? where can i find out why?
not gonna happen
Old Sep 10, 2004
wonderz's Avatar
wonderz is on a distinguished road
you can always try to get the setup from the Civic RS from japan. i believe they are 4dr. awd with 127hp. shipping gonna be expensive tho.
Old Sep 10, 2004
abmerop18's Avatar
the rs is not awd
Old Sep 10, 2004
MegaHurtz's Avatar
Would this not require rotating the engine 90 degrees and adding a transfer case and front axle?
Reworking both the entire front AND rear of the car?
Naw don't think it's gonna happen, for less than 20 grand at least
Old Sep 10, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
i heard of a rwd integra that drifts. it used the standard GSR B18 engine, but with a previous generation CRV transmission (the CRV with the B20) and transfer case that transferred power to the rear wheels with custom axles.
so since the new CRV uses the K24, and assuming that the CRV K24 4WD tranny will bolt right up to lets say a swapped K20A2, you could have a 200 HP 4WD civic, that is, with lots of modification
Old Sep 10, 2004
sw388integra's Avatar
just buy a crv...it can happen, if ur pockets are stupid fat or Jesse James is ur homeboy!
Old Sep 11, 2004
wonderz's Avatar
the rs is not awd
didn't notice they changed the naming... so its call the X4 model now... anyways, yeah, 1.7L VTEC with AWD...
here is the link:
http://www.honda.co.jp/auto-lineup/c...ata/index.html
even if you don't really know japanese, i assume you can still read the FF / AWD part
Old Sep 11, 2004
zen_master's Avatar
THAT IS ONE SWEET RIDE!
ok, so this is what my friend talking about.....the X4 model.....awd....
did you guys looked at the taillight of civic ferio and the HDD navigation?
Old Sep 11, 2004
wonderz's Avatar
i think most ppl already know about the jdm taillights...
HDD nav on that civic is awesome... too bad only for japan...
Old Sep 11, 2004
reytito's Avatar
how about two engines?
Old Sep 11, 2004
Nitto's Avatar
gone
Nitto will become famous soon enough
im moving to japan
ROFL
i want this:
http://www.honda.co.jp/auto-lineup/integra_r/
Old Sep 11, 2004
tfnaaf's Avatar
BLDNPSI Mod
it can be done, its just time and money and you need a lot of both! Never say never!
Old Sep 12, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
If nasa wanted to do it Im sure they could
but I think your out of luck
Old Sep 12, 2004
Danka02's Avatar
SICCMADE
Danka02 is an unknown quantity at this point
the awd in a crv is different form those of an evo or wrx, crv was ment for "off roading" not handling the road at high speeds, but if you could get a new diff for that kind of traction that would be one sweet setup
Old Sep 23, 2004
modoman's Avatar
I almost had to redicule this statement before I realized that the quotes around off roading explain the silliness of the statement.
Old Sep 25, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
it can be done.. a shop out here got a full crv drive train and put in in a 2000 coupe... but gotta tell you.. when i see the guy he says he runs into problems at least once a month with something
Old Sep 25, 2004
Nodnero's Avatar
Go to Japan or Indonesia and get a Ferio. That'll be the only AWD that wont break.
Old Sep 25, 2004
Got Boost???'s Avatar
Nope, the AWD civics in japan still have the engine mounted horizontally.
However if your looking to launch like an Evo then I hate to tell you that just looking at the civics AWD system, that it is very weak. A mechanical AWD system is the strongest, a viscious clutch AWD system in the 2nd strongest. And way way for back in last place in a fluid pump AWD system is by far the weakest.
jordan1794
Jun 11, 2015 09:14 PM
Dan Head
Jun 10, 2015 01:31 PM
doncarbone
Jun 8, 2015 03:37 PM
klam
Dec 15, 2001 12:22 PM
supercivic01
South
Nov 30, 2001 11:27 AM
