Can anyone help, I stripped my nuts!
Old Sep 15, 2004
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
how do you take off a TIGHTLY wound nut that is completely strippped? Its the center bolt holding the headers to the exhaust manifold so theres not much room and it is stripped really really badly. I tried buying a "stripped nut" recovery socket set but that just made it more stripped. I don't wanna drill it. . .
Old Sep 15, 2004
Ledbelly's Avatar
Im the man in the box
this happens to me all the time ... i use a dremel tool and CAREFULLY cut off the nut takes practice tho to do it right... what exactly did you strip
Old Sep 15, 2004
2K1Civic17"Gabe's Avatar
take it to a shop, sorry.
Old Sep 15, 2004
FALKEN's Avatar
Civicforums Junkie
moved to the Tech Stuff forum
Old Sep 15, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
exactly what ledbelly said.
Use a dremel tool on the side (may have to do it on 2 sides) but don't go all the way to the threads. Then when you are all the way through either use a screwdriver to break it off or a hammer and small chisel. Same thing happened to me right before my turbo kit went on. Added 30 minutes to the project time.
Old Sep 15, 2004
Ledbelly's Avatar
ya the most important thing is not to damage the threads on the bolt
Old Sep 15, 2004
the dremel didn't work for me - but then again i didn't keep at it for long. How long does it take and what exactly am i supposed to do. when i did it the bit just wore down the nut a little. am i using the right bit? damn, this sucks. . .
Old Sep 15, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Use a cutoff wheel on the dremel....
Old Sep 15, 2004
Yeah what they said. For some reason I thought this thread was about some other kind of nuts
Old Sep 16, 2004
Mr.Modify's Avatar
LMAO @ the thread title
Old Sep 16, 2004
shmik1's Avatar
ouch
Old Sep 16, 2004
2k2civic's Avatar
Use a chisel....always worked for me.
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Hollywoodsnake
Sep 20, 2015 12:58 PM
stank
Sep 16, 2015 07:40 AM
