throttle cable
Old Sep 5, 2004
Farage's Avatar
I like you! do you like me?
throttle cable
finally, i tightened my throttle cable today. it was a piece of cake and really makes the car much more fun to drive. if you have not done this yet, give it a try.
Old Sep 5, 2004
xstrdnr's Avatar
xstrdnr is an unknown quantity at this point
ok when i did mine i really couldnt tell do you put it real tight where the throttle is kind of pulled back cuz if you feel it the, plastic thang it can go back a lil but it wont make it idle up if you know what i mean
Old Sep 5, 2004
Farage's Avatar
ok the simplest way to explain it is: move the 2 nuts 1/2 an inch to the left.
Old Sep 5, 2004
Farage's Avatar
its not supposed to have a higher idle. thats bad. its supposed to be where if you slightly tap the throttle, the car responds very quickly.
Old Sep 5, 2004
It's different for every car. You need to adjust it so there's about 1/2 inch of slack when you push your finger down on the cable. Then after that much, it should start to pull the lever, and then the actual valve should open. The initial lever should be resting on metal and not being pulled by the cord at rest. If it does, your rpms are gonna stick when revving and on comes the cel.
Old Sep 6, 2004
Farage's Avatar
what does sticking rpm's mean?
Old Sep 6, 2004
You rev the engine and let go of the gas. Instead of smoothly dropping back to idle rpms, it stops around 1k for a few secs.
Old Sep 6, 2004
UltimateWarrior's Avatar
Pimp My Ride!! Please!
UltimateWarrior is an unknown quantity at this point
I guess I got real lucky because I adjusted it perfectly the first time. You're right, it made the car feel fun, almost like I put some mods in the engine! I can't believe how loose it was from the factory. This was one of the best tips I discovered here on this site so far.
Old Sep 6, 2004
gangrel138's Avatar
gangrel138 is an unknown quantity at this point
It's really weird how our throttle cables are so loose but my dad's '99 EX has the recommended 1/2 inch of slack and he's never adjusted his t-cable.
Old Sep 6, 2004
Yeah when I first went to tighten mine, it had almost 2 inches of slack and was drooping down!
Old Sep 6, 2004
gangrel138's Avatar
Ditto. The difference in throttle responsiveness is night and day after you do the adjustment.
Old Sep 8, 2004
grindsman's Avatar
grindsman is an unknown quantity at this point
could someone explain me how to do this exactly please?
Old Sep 8, 2004
http://www.7thgencivic.com/forums/sh...d.php?t=168120
Old Sep 8, 2004
I have a sticky post in vehicle problems forum, and the diy on the site has pics.
Old Sep 9, 2004
2K1Civic17"Gabe's Avatar
SHould it still be tightened if you take out the part under the gas pedal? It lets you push down more on the gas. It seems like if I did both, I might snap the cable? Not sure, does anybody know what I am talking about? there is a black pieve under the gas pedal that you can remove.
PM me please somebody
Old Sep 10, 2004
gangrel138's Avatar
I'd be really careful about doing that. With the stock tension you might be fine but if you take up the slack and try to go Wide Open Throttle you could risk snapping the throttle cable.
Old Sep 10, 2004
Ledbelly's Avatar
Im the man in the box
remember that your car should only idle around 700 rpms
Old Sep 10, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
ok, there are two strings/cords behind the throttle body, i've read both DIY's and do not know which one to adjust, or both? can someone help me? thanks
Old Sep 10, 2004
It's the one closer to the steering wheel that you adjust. The one further away from the front of the car. The other is for cruise control.
Old Sep 10, 2004
Taryon's Avatar
Taryon has a spectacular aura aboutTaryon has a spectacular aura about
Yeah, if you're working on your engine from the driver's side, it's the cable on the right (closer to the back end of the car). Just watch your idle rpm's -- it shouldn't be much of a problem but better to keep an eye on it. Mine idles at ~800 now, but I like the responsiveness a lot more.
Old Sep 10, 2004
Shlomo's Avatar
yeah, i figured it out and took it out for a much needed "spirited" drive. Thanks for your help guys.
Tyler93
Mar 20, 2016 09:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Bruce2
Sep 27, 2015 08:45 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Bricoleur
Sep 9, 2015 12:30 PM
