Air Intake question (more than standard question)
Old Aug 21, 2004
Grail's Avatar
Grail is an unknown quantity at this point
I have already did some searching and am interested in the K&N FIPK intake for my car, but I am wondering if anyone concerned about the small particle problems have tried out the Precharger Filter wrap or Airforce Precleaner as well?
Precharger: http://www.knfilters.com/wraps.htm
Airforce Precleaner: http://www.knfilters.com/airforcewraps.htm
Ideas on which would be better for smaller particles?
I'd also like to confirm that the Gen II FIPK would work fine on my 2004 Civic SE (VP/DX for those in the states) Sedan. K&N's website doesn't mention the FIPK on the listing for 2004 Civic when using the application finder.
TIA
*Edit: Here is the link to the filter I'm wondering will fit my car.
http://www.knfilterchargers.com/sear...x?Prod=57-3513
Old Aug 21, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Use Synthetic oil on your car and avoid using the pre-cleaner...the syn oil will keep the small particles suspended in the oil thus preventing damage to your engine...the pre-cleaner is basically not necessary...as for the other stuff...not sure about that...
Old Aug 21, 2004
The precleaners are for flitering larger particles. If you're worried about particles getting in the engine, K&N is not the way to go imo. Apexi is the only company where the filter is actually effective, but they don't make a system for our cars. Remember the tradeoff--better flow rates for reduced filtering capacity. The difference isn't that much anyway. Just keep the stock intake. It's very efficient and keeps backpressure while filtering the air. If you want some more air going into the engine, get the throttle body bored out. That way you get the benefit without all the problems.
Old Aug 21, 2004
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
but if you have an intake, the best filter to have is, apexi?
Old Aug 21, 2004
Right, but it's a hard one to make fit. The filter bolts onto their intake specifically.
Here's a little something.
http://mkiv.com/techarticles/filters_test/2/
Old Aug 22, 2004
Grail's Avatar
Hmm... Thanks guys. Anyone heard/tried to modify their kits to fit? I'm looking for bolt-ons/minor mods to increase throttle response. I'd like to not try lightweight flywheel at this time... Maybe lighten the stock flywheel a bit...
Oh yeah, as soon as I get close to 8000km/5000miles, I'm switching to synthetic and mobile1/kn oil filter.
P.S. I'm still somewhat a noob, so bare with me please. Boring out a throttle body has what effect on an engine?
Old Aug 22, 2004
It increases the overall diameter of the throttle body opening. So you'll get more air flow at all rpms. I have one with the stock intake and it helps a bit. Not much tho. Also make sure your throttle cable is tight. There's a diy here and something in the vehicle issues forum. Hyper voltage system and ground wires might give some more torque as well.
Old Aug 22, 2004
xstrdnr's Avatar
xstrdnr is an unknown quantity at this point
I have a lx 2001, can i get my throttle body opened ? And whats this hyper voltage system? where can i get mo info about it?
Old Aug 22, 2004
Search! There's tons of info. Here are thr threads I started about it. Also check out maxbore.com for the TB boring service. I guess mine was the first 7thgen he did, but the pics speak for themselves.
http://www.7thgencivic.com/forums/sh...ight=tb+boring
http://www.7thgencivic.com/forums/sh...+wires+and+hvs
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
808specifxz
Nov 17, 2001 10:39 PM
Hobby2K
Nov 9, 2001 04:08 PM
