Check Engine light for brake fluid?
Currently boosted at 0 psi.
Rep Power: 0 Check Engine light for brake fluid?
Hey, I just finished installing a siren in my car today with a very experienced friend. Anyways, as we began to work, he pointed out that my brake fluid was low.
We finish the job [with no splicing] and the cel comes on. Could this be b/c of the brake fluid?
I have 17,7xx miles.
Rep Power: 429 first fill your brake fluid resovior and see if the light goes off. If it doesnt, then take it to autozone and have them scan your ECU to see what the problem is.
Rep Power: 0 How much will that cost, approximately?
And any recommendations for brake fluid. I don't care about the price, really [high-rolling me].
1 Post
Rep Power: 0 Your "Brake" light should come on if your brake fluid is low. The CEL is likely due to some other cause. Did you maybe disconnect a sensor during the install and forget to plug it back in? Is your gas cap on tight?
Rep Power: 429 well take it too autozone and have them scan the ECU, then you will know your problem. Or maybe try this:
Disconnect your negative battery cable for 15 sec, then re-connect it and let the ECU reset itself and see if it goes off. You never know, it might work.
Rep Power: 0 My goal is not to make it go away, but to find out why it came on.
Thanks for the help, I guess I'm going to autozone.
Maybe later this evening.
Xuhme
21
08-07-2023 03:40 PM
tylerginevan
04-27-2015 12:29 PM
bahena08
04-11-2015 05:09 PM
