- Cutch Noises?? Engine Rattle??
- Pissed of of rattle: DIY deadening part 2!
- Honda OEM Fog Light Template
- Tilting License Plate Frame.
- Alarm installed and won't work...?
- oil pan bolt tq specs
- 2000 DC 4-2-1 conversion to a 2002?
- Anyone know how to reset the ABS indicator light?
- quick gas gauge question
- HID retro
- Sway Bars
- Yellow Indicators 7443
- Grinding Noise
- Reset ECU after Intake/Header/Exhaust???
- rsx dash in a civic
- dx to ex swap info...
- resin for cf?
- e-brake one click = traction control?
- HELP!!! Big Problem
- Colder thermostat
- Everyone Please Verify Something For Me On Your Car!!!
- Update on the oil cooler project from hell
- No More Mirror Rattle!
- MEgan Racing
- Can the D17 be made into a DOHC ?????
- o2 Sensor
- Exedy ebay clutch?
- Rear brake swap
- Front Sway Bar
- got my wideband O2 today
- Emergency
- 96 DX Air Intake
- fiberglass trunk install question
- tuning with headers
- Engine died while driving, D17A, sedan yr 2002
- volts dropping
- What mods can i apply to my 01 Civic????
- DIY Mods
- Clutch or Manual Trans problem???
- 02 ex will not run right
- Breather hose
- Axle broke on my 02 Civic SI
- body kit ?
- engine idle
- Hissing Noise?
- Cai
- is my downpipe loose?
- OEM rsx steering wheel w/airbag
- Intake problem
- Turbo effect on Gas Mileage
- programming remote
- All Wires the Same In Hondas?
- bend ignition?
- need car to run cooler radiator cap/thermostat ?
- Cai
- Vtec?
- exhuast size
- any of ya'll done a power window swap?
- Autometer water temp Electric gauge
- DIY Fog Light Help!!!
- removing city light bulb on headlamp
- 02 Fog Light Installation DIY
- Shaved cylinder head
- Muffler Scilencer
- 04 Tranny's are awesome!!
- Venom
- remote/acc wire
- DIY: Cabin Air Filter Replace
- Vtec problem....
- different types of exhaust resonators
- door open/close button problem
- who has tranny cooler ? on 5 speed
- Not impressed with MPG!
- Cam Install..
- Will EX exhaust parts fit an LX?
- Help... catback problem
- Fuel Hose???
- What would happen if you were to...
- HELP!!! Almost Installed 04-05 fog lights (w/ pics)
- How Do I Put This Cam Gear On And What Degree?!?!
- EX Header for LX?
- A/F gauge rich????
- Broke Something
- Painting XM Satellite Antennas
- VAFCII and ex head question
- Help with emanage on Lx
- hardest black headlight problem question ever!
- weird sensation
- Si seat install help
- rsx strut bar
- SRS unique??
- DIY: Remove badges
- i got a problem and need some help
- what mods (N/A) ??
- Question: Where's the IAT sensor?
- Turn Signal Help!!!
- looking for diy
- performance cv half axle
- smoke?
- what interior sedan parts fit in a coupe?
- Need Help On Replacing Trunk Release Cable!!!
- Engine/Tranny Problem!! HELP!!
- Weight reduction in preocess *Pics*
- 2004 cai into 2005
- tach installation
- 3 stage vtec
- Selling my 2004-2005 Civic Si Wheels + tires
- ebay cai induction kit
- Flywheels and clutches
- Need Header For 04 Civic LX
- 04-05 Civic Projector Headlights
- Sound when Lights Left On Doesn't Work
- New problem with Cruise Control.
- Is this worth it?
- AEM EMS Review
- Transmission swap?
- 15'' in a 7thgen?
- Air/Fuel Gauge and O2 Sensors
- Painting Interior Panels
- d16 manifold
- My car is running rich as hell
- diy: my throttle body heater bypass (pic!)
- Engine light on after shampoo???
- Fibre glassing.. hrrmm.. help
- Valve Cover Fitment?????
- Question on steering wheel!
- oil filter comes off counter clockwise or clockwise?
- Possible to paint splash guards?
- Headers Torque Spec. ?????
- MisFire?
- 01 auto tranny to 04+ tranny
- is it only in my head ?
- DC Sports TCS
- hood latch + rad support
- Car won't start???
- Replacing struts. Some problems
- Major Fvck Up for the year 2005
- DRL Module location?
- Rear Window Removal
- question about smoked taillights?
- SI seats in a coupe
- Where can I buy this???
- Is it worth it......
- Rear Seat Latch Relocation
- Adjusting rear camber kit
- Srs Unit Location
- Just finished installing my new transmission - shifts like butter!
- Finally a CAM! But not for non-vtec
- Problem with Turbo Timer
- need help w/air fuel ratio gauge
- She's Dead!!!
- SHORT SHIFTER, short shifter
- Air Fuel Gauge Hook-up
- Top mount bolts won't come off...help?!
- Shakey Shifter
- speedometer problem
- Clutch question
- threads on the shifter?
- DIY - Smoking your Tail lights.
- how much to mill head?
- 02 simulator problem
- VAFC2 help for lx to ex conversion
- Quick H E L P!!! Bell Housing!!!
- Headlight Bolt - Driver's Side
- Clicking noise when releasing the clutch
- Lookin for the DIY black housings headlignts!!!
- DIY - Smoked Taillights for Sedan
- what does a bad CV joint mean?
- Blackout!
- Best Silencer for 2inch piping from the cat?
- Scratches on HEAD UNIT!!
- burned out light (guage cluster)
- Drive Shaft???...
- free garmin eTrex or magellan GPS
- Installing Racing Seats
- lighting...gauges, brake light
- Safc Or Greddy Piggy Back
- extend the O2 sensor wire
- Need Clutch/Flywheel Info
- Anyone ever change their clutch master cylinder?
- Speed Limiter??
- Problem with side skirts
- SRS Light - Didn't Unplug Anything To Set It Off
- ReWiring Cruise Control....Anyone?????
- Screwed...
- questions on factory alarm system
- New 04-05 civic projector aimming
- overheating like crazy, help!!
- where have you plugged your 12v accessory
- srs light from type-s seats
- What is purple gas?
- Faze tach install ??
- DIY: amber signal without the reflection
- new auto or swap to manual
- help!!! clutch problem
- another rattle
- Oem Foglights DIY??
- bad gas mileage
- Click noise
- LX to EX head swap
- Integra headlight question ...
- Problem installing tyc projectors??help
- universal 2-step
- ecu question
- Question about a lip kit
- Exhaust/Muffler question.....
- HELP! Will + rep you if you do! My friend drives a 97 Accord LX
- cat back oem rsx type s
- Seat Belt Chime
- Widening the knob hole?
- oxygen sensor
- Auto trans problem ?
- Recalls!!!
- Painting Urethane!
- car acting up rev meter bouncing up and down
- Car problem idle funny
- VTEC Controller
- VAFC2 help!!
- K20 Swap???
- Back & Forth Revving HELP PLEAZE!!
- Maintenance Light
- Whining noise from motor?
- S2000 exhaust
- ACT Stage 2 ain't sh1t, purrfect auto sux a$$!!!
- Which Wire??
- how do you adjust the headlight for 02 civic?
- removing tint?
- vafc2 question help?!?!
- HELP o2 sensor
- welp, fixed brake system. remember kids, dont press pedal when pads are off...
- Dash Lights and aillights problem (possible Fix)
- Interesting read: Clutch Troubleshooting
- How much is our sunroof tinted?
- weird noise. Suspecting exhaust system. Need help!!!
- ? About taillights
- ecu for 01 civic
- Great EL cable diy
- 01 neon head lights??
- Ponys+Tranny= Pwr Lss...Fix?
- Air Intake Filter?
- i did search... now is it worth it?
- how come my trunk doesn't stay up?
- grounding kit tech and SUNS
- Exhaust Gasket Leaking
- recall notice
- Speedometer help
- Car might be sucking water in, help
- Honda's electronic governors
- vtec on a switch
