diy: my throttle body heater bypass (pic!)
Old Apr 17, 2005
Smile diy: my throttle body heater bypass (pic!)
I finally got around to doing this mod. Well it simply imvolves removing the flow of coolant through the throttle body so the air coming in stays cooler. I got a small (2 inch) plastic pipe seen in white below and connected the coolant hoses going to the throttle body.
Note the location and connection of the hoses and the tube. The one on the right came from the lower inlet on the TB, while the left one came from the top inlet on the TB. I used mini hose clamps to hold the hoses on.
Finally I put vacuum caps over the TB inlets to prevent dust from entering. A fairly easy mod, most of the time was spent gathering supplies and taking the air cleaner off.
Now for the differences. There is no idle fluctuation at all, and no engine functions were negatively affected. I went driving afterwards when it was 80 degrees out to make sure there were no leaks.
I felt a noticable difference driving tonight at 60 degrees. I started up the car and drove slowly until the temp gauge goes to normal. Now at this point the car would still feel peppy and have decent response. But after some more driving with the temp at normal, the car would feel slower and engine makes growling (bogging) noise and just runs sluggish. Well after the mod, performance stays the same as when the temp gauge first reaches normal. All I have to say is...I've been missing out! This is a great mod and feels like I added a cold air intake. Performance doesn't decrease after the engine gets up to temp. It stays the same, even after 20-30mins of driving at high rpm.
Old Apr 17, 2005
GreatWhite02's Avatar
4 cyllinders are good but 5 is better!
GreatWhite02 is an unknown quantity at this point
Looks like a success! Im getting ready to do that mod as soon as i get some spare time!
Old Apr 17, 2005
Yup I got the stuff from ace hardware. Don't goto autozone or car places. They don't have anything. And I think the copper tube is 1/4 inch, not sure tho. It was slightly bigger than I would like, but still worked.
I think I'll put it back to stock in the winter, although older cars don't have TB heater and still do fine so idk.
Old Apr 17, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Suggestion for anyone wanting to do this.... I've only seen one guy ever do this, but it was genious. Put a ball valve in the coolant-in line. Then when you don't want it running, shut the valve, boom, no coolant flow. When you're done beating on the car or whatever reason you shut it off for, just open the valve, coolant flow resumes. There's no ill effects to it since once the inlet hose fills and can't go anywhere, the coolant just keeps running past it in the lines, and the exit line doesn't care.
Old Apr 18, 2005
S2KREY's Avatar
formerly 2k1CivicRacer
S2KREY is on a distinguished road
yeh ive done this way back took me around 30mins to do the diy not bad does keep the throttle body a few degrees cooler than with the coolent going threw it. besides all that you should do it if you live in places where in the morning the water dosnt freeze
Old Apr 18, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
this is why i like living in phoenix, leave it off all year
Old Apr 18, 2005
gsrchad's Avatar
gsrchad is an unknown quantity at this point
does the gsr motor have this also? I have wanted to do this for a while, but i always examine my tb and cant sem to find what your talking about... a few hp is cool with me !!!
Old Apr 18, 2005
Al Gore FTW's Avatar
jdmtytedoridori
that sounds awesome, im doing that
Old Apr 19, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
I did this while back. Throttle body use to get hot as hell before and radiate heat onto the intake itself. After doing this intake and throttle body stay pretty cool to the touch. I wanted to put some kinda T valve so I could turn it on and off but couldn't find anything small enough. So being in Louisiana I just bought a little brass barb fuel tube??(can't remember exactly what it was called or the size. Autozone $3.00) Stuck that on the ends of the fluid tubes and used the existing hose clamps. I put a couple vacuum caps over the holes on the throttle body to prevent dirt and stuff from getting in there.
Old Apr 19, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
I used a plastic elbow for the windsheld wiper lines to connect the hoses, no leaks. I also used white vaccum caps like Redline04 did.
Old Apr 19, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Instead of connecting the two hoses, I bought a new long one. Less chance of leaks. I also didn't cover the throttle body with anything. Just removed the hoses.
Old Apr 19, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i had mine like that but left the throttle body extensions open(nothing over them, unlike yours)... but its back to stock now, i have a cai, wonder if i should switch back since its summer?
Injen
Old Apr 19, 2005
ya switch back. It made a huge difference driving around. Not sluggish at all during the hot days when before you could feel it bog down. I might even leave it during winter, cause I can't see how moisture would get past the filter to the tb anyway. Older cars don't have the heater and I don't see over half the cars here having any problems.
Old Apr 19, 2005
injencivic's Avatar
^ mine was setup like that all winter and ran fine, hell it was like that for about 2 years.
injen
Old Apr 19, 2005
Redline04's Avatar
injen
Had mine like that too just before winter. Temps were in the 30's at night, but never dipped below freezing. The car pulled so hard at night when it would go down to like 36. Loved it.
Old Apr 19, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
wat size tubing did you guys use to cover up the inlets on the TB?
Old Apr 19, 2005
I just bought a few sizes. I guess 1/2 inch should work.
Old Apr 20, 2005
crazyasian's Avatar
cool thanks.
Old Apr 20, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Reading this I just can't understand how this mod makes hp. The air going through the throttle body is only there for a split second and I just doesn't seem like a hot throttle body would heat up the air in that amount of time to lose horsepower that you would have with this mod. Maybe someone can explain it to me better...
Old Apr 20, 2005
Well then think about what else is touching that burning hot throttle body? The intake manifold, and what about the actual intake? The air may be moving fast, but it still heats up going through all the pathways. Having one cooler path reduces air temp enough to feel a difference.
Old Apr 21, 2005
crazyasian's Avatar
well i went to advance auto but couldnt find a 1/2 size hose. are there any other sizes that might work. cause i believe i saw 3/8 and some other sizes. also wat size pipe would work. cause i saw a 3/8th size copper pipe
Old Apr 21, 2005
I just said in the post NOT to goto an auto store. Look for it in a hardware store. I went to ace, but any other place should have some metal cylinder.
Old Apr 21, 2005
crazyasian's Avatar
eh. i found a metal pipe nd some other stuff. so it worked out just fine.i added some hose clamps for the hoses on the throttle body just in case they fly off
Old Apr 21, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
main condenser
Now that is an idea! especially for us NewEnglanders, but I got one thing to say; my major is marine engineering, and on our main/auxilary condensers, or things like our lube oil coolers, it is recommended throttling our valves on the discharge side, because throttling(or just closing) may create an air pocket inside the tubes, and we all know air is not a good cooling meadian...
Old Apr 21, 2005
fullgrown's Avatar
<---- I am really this short in person!
fullgrown is an unknown quantity at this point
is this similar or the same to the one that's in the DIY section??
http://www.7thgencivic.com/forums/sh...d.php?t=154959
Old Apr 21, 2005
crazyasian's Avatar
its the same. smelt a little bit of coolant burn but i guess thats just from the spill that came out of the hose lines. im gonna double check just in case
Old Apr 22, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
let me help you guys out a lil bit.
you dont even need to buy anything.. take the end of the output hose and connect it to the input connector. (see pics below for explanation)
also if you guys were wondering about how the throttle body heater works... check out the second pic.
edit. the coolant flowing through doesn't just heat the air. it heats the throttle body itself. As others will say the throttle body stays much cooler now with no coolant flowing to it.
Name:	tb 7th01.JPG
ID:	52387   Click image for larger version
Name:	tb 7th02.JPG
Old Apr 22, 2005
That's the most retarded thing ever. Why did they want to heat the air? Good pics tho thanks. It was around 50F today and felt like below 30 wow.
Old Apr 22, 2005
XSRCivic's Avatar
well from what i heard heating the air enables a better start for the colder areas. have you had any strange starting since you did this?
Old Apr 22, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
^^^if we don't buy the pipe to connect to the in and out hose, where do we connect the IN PIPE to so there's a continuous flow?
