speedometer problem
Old Apr 11, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
speedometer problem
i took out my needle yesterday, and i can't get the speedometer to work right now when i put the needle back in? It kind of works, but like a clock, not a fluid motion, like its supposed to. And it doesn't go up and down quickly as it should. All my other gauges work, except the speedometer. Any Advice?
Old Apr 11, 2005
ojay's Avatar
ojay is on a distinguished road
try this:
Originally Posted by tinman
Did you mod your cluster? Maybe the needles are sticking.
Try this:
1. Push and hold the trip/reset button.
2. Turn the lighting switch on.
3. Turn the ignition switch on.
4. Within 5 seconds, turn the lighting switch OFF, then ON and OFF again.
5. Within 5 seconds, release the trip/reset button, then push and release the button 4 times repeatedly.
This starts the Gauge cluster self diagnostics.
The beeper will sound, the lights will flash, the LCD will flash, and most importantly, the needles will sweep all the way back and forth. If they/one does NOT sweep properly, replace the cluster.
To exit diagnostics, turn off the ignition.
Hope this helps. If you don't get it the first time, try again. Timing is important here.
Good luck.
Old Apr 11, 2005
ACURAwerx's Avatar
thanks ojay!
Old Apr 11, 2005
ACURAwerx's Avatar
so can i put my needles anywhere on the gauges and they will self reset themselves?
Old Apr 11, 2005
CivicStudEx's Avatar
CivicStudEx is an unknown quantity at this point
I had a similar problem when i put in gauges, it was almost like the speedometer would get stuck in certain places, is that whats happening to you? cause the speedometer might just not be centered. thats what happen with me, I just had to wiggle it back and forth to get it level.
Old Apr 11, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Never take your needles off. I will never by gauge faces or mess with a cluter in any way, it's just a total waste of time and money, now you know. Your gonna have to go on EBAY and find one, there around $120.
Old Apr 11, 2005
ACURAwerx's Avatar
so you put it back in, and wiggled it back and forth while u were driving? and then it started working right?
Old Apr 11, 2005
Not while I was driving, the car was parked, but i just adjusted it till the needles starting moving fluidly and falling back down without sticking. They work perfect now, no problems. The gauges weren't worth the agrivation like the post above you said. If i'd have to do it all over, I wouldn't! But its in the past.
Old Apr 11, 2005
ACURAwerx's Avatar
Originally Posted by ojay
try this:
did you ever do this diagnostic test ojay? I tried to do it and it doesn't work for me.. or maybe im doing it wrong. does ignition mean turning on the car, or just to the first spot? and does lighting mean the first lighting or the second one (headlights) thanks
Old Apr 11, 2005
C2i0v0i1C's Avatar
SuperMODrizd
last i heard dont take the needles off
Old Apr 11, 2005
C2i0v0i1C's Avatar
SuperMODrizd
from experience, i did back in the day, had to get a whole new cluster
Old Apr 11, 2005
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
i want to give this a try. it says within 5 seconds turn the lights off, on, off. in this same 5 seconds do i have to release the trip button?
Old Apr 11, 2005
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
I've taken my needles off and put them on, I'd say about 5-10 times...and it works fine....my suggestion is this...fill up your tank and leave your car off for a bit...then put on your temperature needle (obviously at "0"), then turn on the car and put on your gas needle (at full) our cars (the ex) idle at about 500 or so, so put that one there and then rev the car til it hits the rev restrictor and see if its accurate to where u remember...and then for the speedometre get a friend (to follow beside you or lead or whatever and set the needle to an agreed speed...to do this obviously you cant have the clear plastic on....
and then you're set! dont have to buy a new cluster...and if your needles are sticking, maybe you pressed them into hard...I did that, so when I put them back on, I didnt shove them all the way it...and it works like a charm!
PEACE!
Old Apr 11, 2005
ojay's Avatar
yes i have. ignition is the 2nd one (where it beeps and it's ready to be started). lighting, parking lights work fine. it takes a couple tries, but it's pretty cool to see. works with an RSX too.
Old Apr 11, 2005
Listen to DJ, he might be onto something, thats exactly what happened with me, i never took the needles off, but I thought I pulled them a lil bit with trying to get the gauge on (again, not worth the time & aggrivation ). So I kept pushing and pushing, finally realized they needed to be pulled out, once I did that, worked perfectly and haven't had a problem since. Good Luck
Old Apr 11, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
why is everyone taking off their needles all of a sudden, the blue lights diy or something?
Old Apr 11, 2005
ACURAwerx's Avatar
^^ because its cool
Old Apr 11, 2005
ACURAwerx's Avatar
the light behind the needles is so bright! its cool to look at at night
Old Apr 11, 2005
just to verify, i never took the needles off, i just screwed them up with the non-important indiglo gauges (BLAH).
Old Apr 11, 2005
ACURAwerx's Avatar
hey, i did what u guys said (made the speedometer needle a little looser) and did the diagnostics and everything seems to be working gain, thanks for the help everyone! also, what is the piont of the diagonistics, just to see if everything is working?
Old Apr 12, 2005
ojay's Avatar
yeah it calibrates all the needles and lights on the gauge cluster.
youngm
Jun 4, 2015 10:19 PM
izdman
May 19, 2015 03:43 PM
One_PeeJay
May 17, 2015 05:31 PM
Chronic_issues
May 8, 2015 05:40 PM
dragonsblood
Apr 27, 2015 12:28 PM
