dd17a1 swapped for a d17a vtec issues
Old May 8, 2015
Chronic_issues's Avatar
Chronic_issues is an unknown quantity at this point
i just swapped the engines. i used the old harness and computer from the d17a1. the car runs and drives but the egr values and the rocker arm oil pressure valve not hooked up. the d17a1 didnt have either valve on the head or engine. will it be ok or should i switch the heads. also the speedometer dont work
Old May 8, 2015
Re: dd17a1 swapped for a d17a vtec issues
might have less power than the non-vtec engine in there?
speedo is entirely different issue?
Old May 8, 2015
I would not swap anything as long as the computer is happy. No codes?
What have you tested so far? Got any codes? Does the PCM data show any value for VSS?
codys civic
May 31, 2015 03:28 AM
jmdcivic
May 20, 2015 09:52 PM
avenger
15
Feb 9, 2002 12:14 AM
supercivic01
26
Jan 26, 2002 10:11 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
