Recalls!!!
Old Mar 30, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
Recalls!!!
I don't know if this is a repost... but I was surfing online and this is what I found...
Make : HONDA Model : CIVIC Year : 2001
Manufacturer : AMERICAN HONDA MOTOR CO.
NHTSA CAMPAIGN ID Number : 01V380000 Recall Date : DEC 13, 2001
Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY
Potential Number Of Units Affected : 16459
Summary:
VEHICLE DESCRIPTION: CERTAIN SEDANS AND COUPES FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 209, "SEAT BELT ASSEMBLIES." CERTAIN REAR SEAT BELT BUCKLES WERE IMPROPERLY MANUFACTURED.
Consequence:
THE REAR SEAT BELTS WILL WORK PROPERLY AND PROVIDE PROTECTION IN A CRASH, BUT THE OWNER MAY EXPERIENCE DIFFICULTY UNFASTENING THE BELT AFTER THE CRASH.
Remedy:
DEALERS WILL INSPECT THE VEHICLES AND REPLACE THE SEAT BELT ASSEMBLIES THAT WERE IMPROPERLY MANUFACTURED. ONLY BUCKLES THAT ARE MARKED (ON THE BACK SIDE OF THE BUCKLE) WITH AN ASSEMBLY NUMBER BEGINNING WITH 00185, 00186, OR 00187, WILL BE REPLACED. OWNERS SHOULD CONTACT THEIR DEALER FOR THIS REPLACEMENT. OWNER NOTIFICATION BEGAN JANUARY 22, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 02V051000 Recall Date : FEB 08, 2002
Summary:
Consequence:
Remedy:
IN A PREVIOUS RECALL (01V-380), ONLY RIGHT AND LEFT BUCKLES WERE INSPECTED. THE REAR CENTER BUCKLE SHOULD ALSO BE INSPECTED AND CORRECTED IF NECESSARY. THIS RECALL IS BEING CONDUCTED ONLY FOR THE CENTER BUCKLE. DEALERS WILL INSPECT THE VEHICLES AND REPLACE THE SEAT BELT ASSEMBLIES THAT WERE IMRPOPERLY MANUFACTURED. ONLY BUCKLES THAT ARE MARKED (ON THE BACK SIDE OF THE BUCKLE) WITH AN ASSEMBLY NUMBER BEGINNING WITH 00185, 00186, OR 00187, WILL BE REPLACED. OWNERS SHOULD CONTACT THEIR DEALER FOR THIS REPLACEMENT. OWNER NOTIFICATION BEGAN MARCH 5, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
NHTSA CAMPAIGN ID Number : 04V086000 Recall Date : FEB 24, 2004
Component: EXTERIOR LIGHTING:HEADLIGHTS
Potential Number Of Units Affected : 440000
Summary:
ON CERTAIN PASSENGER VEHICLES, THE LOW-BEAM TERMINAL ON THE HEAD LIGHT WIRE HARNESS CAN OVERHEAT AND COULD CAUSE THE LOW BEAMS TO FAIL WITHOUT WARNING.
Consequence:
AN UNEXPECTED LOSS OF LOW BEAMS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE HEAD LIGHT SWITCH AND COUPLER FOR SIGNS OF HEAT DAMAGE. IF HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE SWITCH AND COUPLER. IF NO HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE HEAD LIGHT SWITCH AND ONE MATING PIN IN THE COUPLER. OWNER NOTIFICATION BEGAN ON APRIL 5, 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Check to Request Research. Submit below.
NHTSA CAMPAIGN ID Number : 01V182000 Recall Date : JUN 06, 2001
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Potential Number Of Units Affected : 120649
Summary:
VEHICLE DESCRIPTION: SEDANS AND COUPES. THE HOSE CLAMPS ON THE FILLER NECK TUBE HAVE INSUFFICIENT CLAMPING FORCE.
Consequence:
IN A COLLISION, THE TUBE COULD DISCONNECT FROM THE FUEL TANK, RESULTING IN FUEL LEAKAGE. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
Remedy:
DEALERS WILL CHECK THE HOSE CLAMPS FOR PROPER TORQUE AND TIGHTEN THEM CORRECTLY, IF NECESSARY. OWNER NOTIFICATION BEGAN JUNE 4, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
NHTSA CAMPAIGN ID Number : 01V183000 Recall Date : JUN 06, 2001
Component: FUEL SYSTEM, GASOLINE: DELIVERY:FUEL PUMP
Potential Number Of Units Affected : 56269
Summary:
ON CERTAIN SEDANS, A SMALL AMOUNT OF WATER MAY HAVE BEEN LEFT IN THE FUEL PUMP ELECTRICAL CONNECTOR AFTER TESTING. THIS RESIDUAL WATER COULD CAUSE THE FUEL PUMP TO FAIL DUE TO CORROSION.
Consequence:
IF THE PUMP STOPS WORKING, THE ENGINE WILL STALL WITHOUT WARNING, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSPECT THE FUEL PUMP. IF CORROSION IS FOUND, THE FUEL PUMP WILL BE REPLACED. OWNER NOTIFICATION BEGAN JUNE 29, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
NHTSA CAMPAIGN ID Number : 01V329000 Recall Date : OCT 17, 2001
Component: ENGINE AND ENGINE COOLING:ENGINE
Potential Number Of Units Affected : 295
Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. DURING THE ASSEMBLY PROCESS, THE AIR CLEANER BOX COVER MAY HAVE BEEN DAMAGED, AND A BROKEN PLASTIC PIECE COULD TRAVEL INTO THE INTAKE CHAMBER.
Consequence:
IF THE PLASTIC PIECE LODGES IN THE THROTTLE BODY, THE THROTTLE COULD STICK IN A PARTIALLY OPEN POSITION. ALTHOUGH THE DRIVER CAN ALWAYS STOP THE CAR BY APPLYING ADDITIONAL BRAKE FORCE, OR BY TAKING OTHER ACTIONS (I.E., SHIFT INTO NEUTRAL, TURN OFF THE IGNITION KEY, ETC.), IF THE CAR CONTINUES TO MAINTAIN SPEED WHEN THE DRIVER IS EXPECTING IT TO SLOW, A CRASH COULD OCCUR.
Remedy:
DEALERS WILL INSPECT THE AIR CLEANER BOX FOR DAMAGE. IF DAMAGE IS FOUND, THE DEALER WILL LOCATE AND REMOVE THE BROKEN PLASTIC PIECE, AND REPLACE THE AIR CLEANER BOX LID. OWNER NOTIFICATION BEGAN ON OCTOBER 25, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
check yours!!! click here>>> http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
Old Mar 30, 2005
01civicexboy's Avatar
01civicexboy is an unknown quantity at this point
Wow...enough said
Old Mar 30, 2005
i got my buckle replaced a long time ago when it started sticking. Don't know about the rest but they sound bad.
Old Mar 30, 2005
civic01vtec's Avatar
i got a letter a while ago about the headlights......i never got it taken care of
Old Mar 30, 2005
es2k2's Avatar
Proud to be a civic owner
i've never gotten a recall letter and honda said if you don't get it, that means you are fine.. true statement??
Old Mar 30, 2005
Balut Eating Champ
i got the letter for the headlights, but not the seat belt and the fuel pump! now that I have all kinds of shlt on my ride, i'm pretty sure they will void my warranty or recall on my fuel pump...
lowlife9
Oct 6, 2015 04:39 PM
MamaBear2015
49
Sep 29, 2015 01:12 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Sep 27, 2015 11:33 AM
charmon4815
General
Sep 22, 2015 08:00 AM
