MisFire?
Old Apr 15, 2005
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
MisFire?
Today my cel turn on. I ran to nearest auto shop and see what going on, and i got all those code from ecu code scanner P0301/ 1 cylinder misfire, P0302 C 2 misfire, P0303 C 3 misfire, P0304 C 4 misfire and P0300 random cylinder misfire. Total of 10 codes, what cause all those problem? It seem to drive fine.
Old Apr 15, 2005
ncirom2003's Avatar
there could be multiple things, most likely in your ignition. im assuming your having this shop work on your car so just ask them what they think was the cause, if they arent sure then take it to someone else or honda.
Old Apr 15, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
sounds like 4 codes to me ...
Old Apr 15, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
whats your mods, could be low fuel pressure, compression, VTEC malfunction. Do you notice when it misfires? What other codes are you getting? P0107, P0108, P1128 P1129 (MAP sensor) Let me know the other codes besides the cylinder misfire ones.
Old Apr 15, 2005
5 codes plus extra 5 same codes =10 . I took it to those auto part store
Old Apr 15, 2005
i'm running cai/hp head with test pipe/apexi n1 exhaust/ v-afc2 that all i been running those mod for year and half untill today my cel come on. that the only codes i get is misfire. My car been acting up funny latey like with i start my car it rev up and down untill my car warm up.
Old Apr 15, 2005
scansel912's Avatar
So you dont' notice anything when you drive?
Old Apr 15, 2005
I'm planning to bring it back to dealer but i have to take everything off.
Old Apr 15, 2005
Nope it drive fine
Old Apr 15, 2005
scansel912's Avatar
Idle control Valve messed up? Maybe why it revs like that. I dunno about the V-AFC2 either. Your best bet is to take it to a shop.
Old Apr 15, 2005
ncirom2003's Avatar
my bros audi misfired in one cylinder, you would only feel the car "putting" (i suppose you could call it this) when the air was damp or raining out. sometimes youd be accelerating and feel it just like give up and the car would stutter pretty much. he just needed a coil pack replaced but i doubt you need all 4 so just take it to honda cus even if you figure out what it could be online here youd be better off jus havin them do it.
Old Apr 16, 2005
When i start my car cold early in morning or leave my car outside for couple hrs. When my car is idling around 2k(cold start), if i open my glove box my rpm bounce down around 1k and go back up to 2k. It keep on doing that when i close and open my glovebox. When my car is getting warmer my rpm dropped, if i open the glovebox nothing happen my rpm don't bounce. It could be my ecu because my ecu is next to glovebox or it could be my faulty wires from afc but i have my afc for almost a year?
Old Apr 16, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
Well if it truly is linked with moving your glovebox, then it is no doubt some sort of electrical issue. Loose connection?
Old Apr 16, 2005
ncirom2003's Avatar
yea loose wires, lol that mustve been weird when you discoverd that dude lol
Old Apr 16, 2005
^^ would that cause to misfire? yesterday my cel pop on when i just started my car.
Old Apr 16, 2005
ncirom2003's Avatar
i dont think so, but dude either ur car is haunted or has some real electric problems just take it to honda and tell them everything.
Old Apr 17, 2005
Rufus's Avatar
When I drop my glovebox my horn goes off and I get a boner. Must be something with our gloveboxes
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
