Can the D17 be made into a DOHC ?????
Old May 3, 2005
_Viper_'s Avatar
If so what parts do I need.????
I know that the paseo's have the same setup as our d17's and they are DOHC...
OKOK its a stupid question flame me
Old May 3, 2005
PunkingCivic's Avatar
I need TP for my bunghole
no they cannot
Old May 3, 2005
Overboost's Avatar
Overboost is an unknown quantity at this point
Good question. I'd like to know the answer too. Couldn't we switch the heads off an EX to an LX?
Old May 3, 2005
devilvtec's Avatar
devilvtec is an unknown quantity at this point
You can change the heads, but it's still SOHC
Old May 3, 2005
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
There is SOHC and then there is DOHC two different motors. SOHC has a 75mm bore and DOHC has a 81mm, 86mm, or a 88mm bore (depending on what kind of motor) that alone is why you can't.
Old May 3, 2005
_Viper_'s Avatar
hmmmm that and the ecu would just fry i guess
Old May 3, 2005
bickford05's Avatar
bickford05 is an unknown quantity at this point
yeah, you cant just switch it to a DOHC
Old May 3, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
ah, **** that site.
Old May 3, 2005
_Viper_'s Avatar
So if i put 2 red x's ill be fine ?????
Old May 3, 2005
C Orndorff's Avatar
The only SOHC to DOHC swap like around like this is the SOHC ZC and the DOHC ZC. Also by the way ZC motors suck ***.
Old May 3, 2005
_Viper_'s Avatar
interesting ..
I was sure that it could be done...
Old May 3, 2005
Wolfgang5884's Avatar
Old May 3, 2005
gh0st's Avatar
TAQUITOS!!!!
only if you pull the engine out and put a b/k series engine
Old May 3, 2005
ajhdragon's Avatar
7thgens official a$$hole
you could probably but a b-series head on it. first pull the block and have the rear oil return hole plugged and you would have to get new head bolt placement. then you would have to hook up a distributer and run all b-series wires. then you would have to change your dash cluster to a b-series cluster to run from the obd-1 ecu. and probably some other odds and end stuff. do able yes. cost efficient no. looking at probably around $4,000 usd for it. and very little power gains and probably 100 codes.
Old May 4, 2005
psychotic_z's Avatar
psychotic_z is an unknown quantity at this point
This has been asked on Honda-Tech a million times and the answer's NO, sorry to say.
Some guys have tried, but the head bolts, oil passages, coolant passages, dowels, etc. all don't come even close to lining up. Not to mention the other machining to match combustion chambers, the electrical problems (the heads use different sensors), and the probability of finding a machine shop that has enough money to throw away to attempt this. It may be possible but it'd be excessively expensive and you'd be pioneering the first one. You're still stuck with a shitty D-series bottom end, anyway.
I was fairly sure the SOHC ZC and DOHC ZC were two completely different motors and the heads weren't interchangable. I could be wrong...
Old May 4, 2005
MiamiUgen7's Avatar
I did it and it works perfectly fine. I have a b18 head on my d17
Old May 4, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
pics??
Old May 5, 2005
Yeah, did Brian Conner and Johnny Tran do the machine work on it? MoTec system exhaust? T4 turbo?
GTFO of this forum
Old May 5, 2005
zachgeyer's Avatar
wtf dude
Old May 5, 2005
blouisgod's Avatar
Life Begins > 6800rpms
i actually took a B17A head from a 90-93 integra gs and matted it to my d17 long block. my ecu was tough to wire and all, but it romps. so far it runs very fast - I've been knocking down si's and rsx's all day long.
Old May 5, 2005
classact307's Avatar
classact307 is an unknown quantity at this point
How in the hel! did you do that... How much in machine work and electronics did you have?
Old May 5, 2005
Seeing as how the cylinders are not spaced properly to match a B-series head, I'd like to know how you supposedly did this.
Old May 5, 2005
I'm glad 90-93 Integra GS's came with B17 heads in the first place, also.
What is with you dumbasses?
Old May 5, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
sure you can make a d17 a dohc motor. When ever / If ever Honda develops a d17 / d18 with a DOHC Head. Then you we can cross that bridge. As for now, no.
Old May 5, 2005
^^^ that STILL doesnt work!
Old May 6, 2005
blouisgod's Avatar
haha you idiots. the answer is NO! It can't be done!
Old May 6, 2005
Clever you!
Did you come up with that by yourself?
Old May 6, 2005
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
Flame On!
Old May 6, 2005
tripledoublegs's Avatar
Euro-Spec
wow, such a waste of bandwith...
Old Jun 2, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Nahh it can be done.. You just have to go to a machien shop, spend about 8 grand, have them custom fabrocate you a new head, and wamb bamb slam you got it! or do and engine swap. thats about it though. either way your looking at about 8 grand.
