Headlight Bolt - Driver's Side
Old Apr 9, 2005
ChiZX's Avatar
ChiZX is an unknown quantity at this point
Question Headlight Bolt - Driver's Side
I'm currently installing a pair of TYC projector headlights. I got the one on the passenger side on fine. However, I can't seem to figure out a way to reach the bottom bolt holding the drivers side headlight. Can anyone help? How did you get that last bolt off? It's in a really tight spot and I've tried everything. I have a 10mm socket but I can't reach the bolt. I now have two different headlights on the car. Help ANYONE!!!
Cheers,
Old Apr 9, 2005
xmeeksx's Avatar
xmeeksx is an unknown quantity at this point
did you partly take off the front bumper?
Old Apr 9, 2005
ChiZX's Avatar
I've already removed the front bumper. I just can't get any tools to the bolt in such a tight spot. I've already removed the other three bolts.
Cheers,
Old Apr 9, 2005
ImPulse's Avatar
u need an extension to get to the one in the back..
Old Apr 9, 2005
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
I had to use two extensions to reach the bolt. Major pain in the ***, but the final product was well worth it, until my halo burned out and I had to redo the whole thing again to put my stocks back on...
Old Apr 9, 2005
ImPulse's Avatar
you dont have to put that bolt back on again...
just leave it off, the headlight is held on by 3 other screws, its fine
and next time if u have a problem you dont have to worry about getting it out
Old Apr 9, 2005
ChiZX's Avatar
Thanks for the tips. I used an extension and was able to get the bolt off. It was definitely a major pain in the ***. The projectors look much better than the stock headlights. I highly recommend them.
Cheers,
ChiZX
Old Apr 9, 2005
CapYoda's Avatar
Escaped Convict
oooh it wasnt listed on the tools that u'll need?
I think I used a foot extension on that sucker. man if you think tahts gay, try extensions on one of the bolts in engine bay that has gay torque spec like 100 lb.ft
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Poopies
Apr 20, 2017 11:36 PM
h4ldol
Jun 3, 2015 03:26 PM
pratik05
May 15, 2015 01:54 PM
johnnieblazze
Dec 6, 2001 03:07 PM
