Front Sway Bar
Rep Power: 286 yes it will fall on you decapitate you and youll lose use of your dong, then your going to turn green from shoulders down and your car will roll off the ramps and down hills with you caught onto front bumper.
or if your lucky nothing will happen <---- im betting for option B
just be sure you chok the tires and e-brake it, good luck
Rep Power: 357 jack stands would probably be better, although i doubt the car will move.
do put on ebrake and wedge some 2 by 4's behind all four tires if you are going to do it on the ramp.
Autocross Junky
Originally Posted by Kubias
I have my car up on ramps right now will anyting happen if i change the sway bar while up on the ramps??? Like fall on me??
Autocross Junky
Rep Power: 357 actually its best to work on anti-roll bars when the suspension is under load. that way the anti-roll bar its self isnt under load.
PC Tech / Autocrosser
Rep Power: 249 I installed my front sway bar while my car was on ramps. No problems. It's just a trick to put the bar in place without an extra set of hands and w/o having to drop the exhaust. Hope you're good at puzzles.
Rep Power: 0 I just installed an EX lower sway on my 01 LX, now i am hearing a popping noise everytime i turn and a small vibration/rattle coming from the lower right wheel area.....what coudl be wrong? Loose? if so shoudl i jack the car up to tighten it down or leave it on the ground(under load)
mrohitredd
06-09-2015 06:37 AM
Rogelio Rey
05-24-2015 08:30 PM
Dorval Andre
05-01-2015 09:37 AM
