Engine died while driving, D17A, sedan yr 2002
Old May 2, 2005
irawhd's Avatar
irawhd is an unknown quantity at this point
Question Engine died while driving, D17A, sedan yr 2002
While driving in heavy traffic, the engine suddenly died. The check engine also lit up. After a while & crank back, the engine runnig fine. It will happen again. Seem that, this problem happen if the engine running hot.
After replacing Spark plugs and Fuel filter, the problem remain. I'm trying to simulate like fuel pump and ignition is failed, but the engine died without check engine lit-up. Seem that, nothing wrong with fuel system & ignition. I'm thinking to bring to the shop for check error code. Any fellow experienced the same?
Tx.
Old May 2, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
did the check engine light, light up before or after it died? how was the temp on the engine just normal, or hot?
Old May 2, 2005
irawhd's Avatar
While engine died, only the check engine light up. It happend together. Engine temp just normal.
Old May 2, 2005
prccivic's Avatar
damn..sorry to hear about the problems, but i am curious to see what it is cause i drive an 02 sedan as well and never had that problem before
Old May 2, 2005
2k2civic's Avatar
take it somewhere and check to see what code that check engine light is refering to.
Old May 2, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
sorry bout that mang, it happened to my car before too... and just to let you know, our civics has been recalled for the defective fuel pump that causes the car to die out... you might wanna bring that to the dealership before you hurt yourself or others...
Old May 2, 2005
irawhd's Avatar
Are you sure the engine died with check engine light up? I'm try to simulate the pump fail, however the check engine doesn't come up.!
Old May 2, 2005
Balut Eating Champ
even if the CEL didn't go off prior to shutting off, it's still maybe the primary cause of it... i.e. ECU senses no fuel, CEL goes off, car died... the reason was they said there could have been some water in the fuel pump, now it that water went to your fuel filter and or to your engine yes, your engine will die out... bring it to PEPBOYS and get it scanned, they won't charge you anything, well atleast here where I live doesn't charge... and let us know the trouble code...
Old May 2, 2005
Logan3024's Avatar
How many miles are on your car? Go get the ECU scanned at autozone or something and quit guessing. Did you reset your ecu yet?
Old May 3, 2005
irawhd's Avatar
My car clocked at 133k km, heavily used for almost 3 yrs. Ecu has been reset twice. Will let all know the finding. At our country, scanning is chargeable at USD20.
Thanks all for avise.
Old May 8, 2005
irawhd's Avatar
Had the resolved. Found the TDC sensor faulty. The code say 08-2 TDC Sensor (1) NOISE. Now, the engine running well.
Old May 8, 2005
manahoonie's Avatar
don't forget to change your oil. dirty oil heats up faster than clean oil.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
jmdcivic
May 20, 2015 09:52 PM
smmahan
Apr 15, 2015 08:17 PM
crazydragon
Nov 7, 2001 05:13 PM
