HELP!!! Big Problem
Old May 4, 2005
sivlercivic02cc's Avatar
sivlercivic02cc is an unknown quantity at this point
HELP!!! Big Problem
Ok, so I went to go get gas today and my gas door no longer opens. So I went to honda and they are wanting to charge me $170.00 to fix the thing. Anyone know how difficult this would be to fix on my own, if I even can?? Any help is greatly appreciated!!!
Old May 4, 2005
Hurts2bStock's Avatar
Shinier than yours, meatbag
yes take it to a real mechanic.......honda will charge you that much to rotate your tires
Old May 4, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
yeah, the dealer sucks for having work done. *** rapping all the way.
Old May 4, 2005
R1Style's Avatar
Don't pay to fix that ****... I know it's a pain in the *** but sometimes my gas door doesn't open either.
All you have to do is pop your trunk, pull the lining forward on the drivers side and reach in there and grab the gas door release cable. Turn it either clockwise or counter clockwise half a turn and the little **** holding the door shut will pull out. This will open your gas door... then once it's open... push the cable back in and turn it to lock it in place.
It might sound like it's really annoying but it honestly take me no more then 15 seconds to do it.
Save yourself the $170
Old May 4, 2005
bradmanuwf's Avatar
I agree. whatever works to save a crazy amount of $ for something simple.
Old May 4, 2005
^^^^give R1 a rep for that^^^
Old May 4, 2005
bradmanuwf's Avatar
I tried, says I've given out too much rep in 24hrs. I've given out 2....WTF! how is that too much?
Old May 4, 2005
Thanks for the help guys, but still curious if anyone else has had to replace it and if so how had it was.
Old May 4, 2005
bradmanuwf's Avatar
nope, mine is fine. no problems with it.
Old May 4, 2005
bickford05's Avatar
bickford05 is an unknown quantity at this point
wow, 170$ is crazy. Good luck
Old May 8, 2005
R1Style's Avatar
Thanks for the rep
Old May 8, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
find a parts car or a junkyard car and replace the gas door/trunk release cable assembly.
detach the lower trim pannel to get to the release cable and lever. then remove the lever retaining bolt and detach the cable from the release assembly.
then from inside the trunk, remove the plastic clips from the driver's side pannels to gain access to the fuel door assembly.
twist the cable 90 degrees to align the tabs on the striker assembly with the slots in the body and withdraw it into the rear compartment. detach the trunk lid release cable from the trunk lid latch.
remove the left door sill plate, the rear seat and the left rear quarter pannel. pull the carpet back and detach all the cable retaining clips.
from the trunk, pull the cable assembly towards the rear of the car.
to install, just reverse the process.
you just saved yourself $170 - parts.
Old May 14, 2005
civic_sedan's Avatar
civic_sedan is an unknown quantity at this point
would this be similar to my trunk release problem?...altho my problem seems to be with the lock itself and not the actual assembly
see thread here: http://www.7thgencivic.com/forums/sh...51#post3033051
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
beveragemp
May 25, 2015 07:11 PM
bsmiley
Apr 27, 2015 01:27 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
