what mods (N/A) ??
Old Apr 21, 2005
el_ben2's Avatar
CivicMexicano Is My Daddy
el_ben2 is an unknown quantity at this point
what mods (N/A) ??
well its time to mod my engine....
so i wanna know what mods do u recomend me to do.... i wanna get the most power that my engine can....
i have an 2k2 Ex auto trinny
and my mods are this...
AEM pulley kit (not installed jet)
HP headers
ebay CAI
HP catback (on the way)
ZEX nitrous kit(ill not considerate it at all)
and im plannin to PnP and a millin of 11.2 to the head...
what other mod do u recomend me??
no swaps... and no turbo...
note: sorry for my bad english
Old Apr 21, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
trottle body heater bypass, 3.3K ohm resister @ 1/2 watt tolerance (orange, orange, red, gold) in your IAT Sensor. DIY Ground wire kit.
Old Apr 21, 2005
bored throttle body
intake manifold
higher compression (domed) pistons
new plugs if you're gettin nos
vafcII to tune air/fuel
aem cam gear (5-bolt model)
new camshaft
hi flow cat
Old Apr 21, 2005
Blahman2's Avatar
cam shaft will be out in a month! What what good would the cam gear be?
Old Apr 21, 2005
um to set the cam timing? It's pretty important for tuning, since you can't just slap on a cam and except it to make power.
Old Apr 21, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
HP headers
ebay CAI
good luck getting that ebay cai on there, i have an auto and it was very very very very very very hard to get a cai on a auto
Old Apr 21, 2005
booba5185's Avatar
psh, it can be that easy, u should see how fast my car was after all the red stickers
Old Apr 21, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
try adjusting your throttle cable (DIY section)
Old Apr 21, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
I think having the aftermarket cam shaft and cam gear would be more beneficial than just stock cam shaft and AEM cam gear?
Old Apr 21, 2005
diskreet's Avatar
Old Apr 21, 2005
el_ben2's Avatar
lol its an m/t one but i make it fit... u know... the key of the life is a dremel & ebay... u can do a lot of things whit that
lol
Old Apr 21, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
Buddy club race spec condenser or the sun automotive one
Blahman2 3.3K ohm resister @ 1/2 watt tolerance (orange, orange, red, gold) in your IAT Sensor.
What does this do?
Old Apr 21, 2005
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
the only mod you well get good gain off of is a good torque converter... the autos in our civics are the porest shifting autos ive ever seen. that and weight reduction, good light wheels and tires will get you the most gains... you might see 10 hp gain from a well tuned bolt on package... and from what ive seen these cars hate raising the compression... idle goes to ****.
Old Apr 21, 2005
ajhdragon's Avatar
7thgens official a$$hole
get some high compression pistons w/good rings and head gasket, upgrde your cooling system to handle the extra heat and make a fuel return line, put a fuel pressure regulator on it run 60psi fuel with 440 injectors. that will give you some power but im guessing your need a vafcII to give the signal to send more fuel, and probably a bigger fuel pump. bolt ons suck its all about internals.
Old Apr 22, 2005
el_ben2's Avatar
mm that sounds me like i need a plan to stole a bank
lol
Old Apr 22, 2005
booba5185's Avatar
lol
good luck i had to have my mechanic do it, it's a b*tch, and u have to bend things, yell that them and make sure the filter doesn't hit the radiator
Originally Posted by Ellocodetroit
What does this do?
tells the ecu that the air going in the engine is colder than it really is, so the ecu advances the timing 1 or 2 degrees
Old Apr 22, 2005
el_ben2's Avatar
ok and its safe to put the resistor on the IAT?
whit sure... i mean for my engine...
Old Apr 22, 2005
i wouldn't put the resistor if I were you. Do the tb heater bypass and tighten throttle cable.
Old Apr 23, 2005
el_ben2's Avatar
ok well... and now.... ummm i dont know how to write it down, but hope u can understand me... how much power does the engine can have?? and how much power does the auto tranny can support??
Old Apr 23, 2005
Auto civics ex starts with 80whp on the dyno usually. I've seen autos making around 150whp after turbo, but obviously it's only a matter of time before something breaks. But for smaller mods like boltons, and stuff, it should be fine. You can always get a transmission oil cooler if you're worried.
Old Apr 23, 2005
el_ben2's Avatar
yeah im thinkin in get one tranny oil cooler...
and what about the block/engine?
Old Apr 29, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
hey you can put that sensor on iat ive had it for almost a year and i love it if i take t off the car feels much slower, hey gearbox i wanna install a tranny cooler on my 5 speed but im having touble finding a pump you got any ideas?
Old Apr 29, 2005
i don't think you're supposed to install it on a manual.
Old Apr 29, 2005
DorKyCiViC's Avatar
Super Duper Member
DorKyCiViC has a little shameless behaviour in the past
Nitrous All The Way Most Bang For Your Buck
Old Apr 29, 2005
mclean987's Avatar
yeh tranny coolers are mostly for auto but they can work a 5 speed aswell you just need a pump and it costs $150 for the pump
Old May 1, 2005
Did you mean you have the resistor (3.3K ohm) inline with your IAT? I haven't looked at it yet, is it a single wire?
Old May 1, 2005
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
Over the past few months I've grown to know that gearbox knows what he's talkin about...
Why wouldn't you do the IAT resistor gear? I tend to take your word as the bible...
Old May 1, 2005
I don't like fooling the ecu into thinking the air is always cold. The sensor is there to calculate air/fuel ratio based on temperature, which you need if you have any interest in tuning your car. Ricers like to put it on so it fools the ecu and in turn makes you run very rich. This not only wastes fuel, but also makes more carbon deposits. You won't gain any hp, in fact your car would prolly run worse.
Old May 1, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Useless mod that has been around since EFI was invented. Tricks the ECU to think its in warm up mode which causes it load up on fuel. Like gearbox said, all it does is make it waste fuel and KILL your gas mileage.
Old May 2, 2005
...ever grinning...
So the only 2 DIY's so far are throttle cable adjustment and coolant bypass?
