dx to ex swap info...
Old May 5, 2005
Hawaiian_Built's Avatar
...JDMDC5...one day...one day...
Hawaiian_Built is an unknown quantity at this point
I was wondering if i did a complete swap, if the mounts would match up. Stupid question but i need to know so i can get the mounts from the guy too. Also does the aem cai dx version fit into the ex. They sell two different intakes for each but would they fit. If i do the swap, looks like i have to change the entire exhaust huh...if im wrong, please tell me. Would the ecu from the dx work with the ex. It probably work but would it work effectively. Thanks for all the help...This is the car that its going into...
Old May 5, 2005
acidbaby's Avatar
The Beez Kneez
its not worht the time and effort that you would put into it.. unless your engine is damaged.. and yes all parts will need to be changed.
Old May 5, 2005
prawdigy's Avatar
prawdigy is an unknown quantity at this point
why would u want to swap in a ex motor? i'd go for a k20 if anything.
Old May 5, 2005
the complete motor with everything needed to swap is only 400 bucks. I do have a k20 in mind for the future but for 400 bucks, thats a pretty good up in hp. Plus the sohc vtec motors have a lot more parts for them than the dx's have. My coupe motor has 36000 miles on it and the sohc vtec has only 2000 miles on it. In my opinion, WHy Not?
Old May 5, 2005
...and as for time and effort, it would only take a weekend with me and a buddy...probably less if we really jam it. With no beers in between if u know what i mean
Old May 5, 2005
cmeias's Avatar
cmeias is an unknown quantity at this point
I would get the mounts and play it safe. you would need the header and the cat from an ex model you can go to a junk yard with a hack saw or something similar and cut it off just after the cat a muffler shop can weld it in place for you. You can use your dx ecu but the vtec wont kick in unless you get a controller you would also need to up the fuel from what your dx ecu is programmed for. I would recoment getting the engine harness and the ecu from the ex. you could just get a piggy back fuel system that has the vtec build in like the vafc from apexi and wire that up to your dx ecu and it will work fine.
Old May 5, 2005
cmeias's Avatar
and to prodigy everyone cant afford a k20 swap there is adifference between 4000 for the k20 swap and 400 for the dx to ex swap. Be more realistic when making suggestions to other members. everyone is not rich and loaded with money
Old May 5, 2005
thanks man...really helpful info. so i could use the dx ecu and all i would need would be a vafc and it would be all good?
Old May 5, 2005
cmeias's Avatar
yeah the vfac will turn the vtec on and you can adjust the fuel to tune it a little better. You will wire the vfac vtec wires straight to the vtec selinoid.
Old May 5, 2005
where is the vtec solenoid located? Does the Vafc hook up straight to the ecu?
Old May 5, 2005
cmeias's Avatar
the vtec solenoid is on the back of the head on the tranny side. The vfac splices into your exsisting ecu wires. but since you do not have the vtec wires in the engine bay you will need to run those to the solenoid. You can pick up a vfac on ebay for about 250. It will work great for future mods since you can reprogram the fuel. That is the way I would go.
Old May 5, 2005
i just wanna say thanks from hawaii for all the info...
Old May 5, 2005
cmeias's Avatar
before installing the vfac I would recomend getting a helms book for your car. This is the manuals that the dealership uses. They are like 75 buck from there website. Well worth it though if you plan on doing the work on your car yourself. It gives you everything from wire schematics to torque specs to a complete engine rebuild it is like 1500 pages of info. I just got my helms book the other day and it is awesome.
Old May 5, 2005
cmeias's Avatar
no problem that is why I am on this site to help others like yourself. Good luck.
Old May 27, 2005
02LX's Avatar
02LX is on a distinguished road
would the samething apply if I am doing a LX to ex swap
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
